how to black out the lights??
Old Jul 29, 2007 | 07:51 PM
W0459732's Avatar
Hey guys,
Anyone on here blacked out there lights, front or back? I wanna do mine real bad, any help, advice and tips welcome.
Thanks
Old Jul 29, 2007 | 07:54 PM
tarmac4g63's Avatar
Yea Evodave does them. search
Old Jul 29, 2007 | 07:55 PM
Gonzo0991's Avatar
search
SilverShadow03's Avatar
EvoDave...he is the light mod guru!!....... Just look him up...He did my lights and they turned out fantastic. Front and Rear.
Old Jul 29, 2007 | 08:13 PM
CrackerJackToy's Avatar
search
Old Jul 29, 2007 | 09:24 PM
SoFlaBBY's Avatar
1. Take them off the car.
2. Pack them up real nice.
3. Send them to Evodave.
4. Give Evodave some money.
5. Post some pics of your sweet new lights when you get them back
Old Jul 29, 2007 | 09:26 PM
bhamEVOguy's Avatar
or if u wanna do em urself, check in the how to's section.there is a write up on this.
Old Jul 30, 2007 | 05:05 PM
W0459732's Avatar
thanks fellas, evodave it is
Old Aug 10, 2007 | 03:19 PM
evo86's Avatar
take the bumper off, take the light off, open up the plastic cover, sand, paint, assemble, put the light and bumper back in.
and you are on.
Old Aug 11, 2007 | 12:20 AM
impreza2darksyd's Avatar
^ dont forget heat gun.
Old Aug 11, 2007 | 04:26 AM
Jakeg97's Avatar
diy and save 150
Old Aug 11, 2007 | 05:19 AM
Adamk24's Avatar
I recently blacked out my headlights and I am really really happy with the results. Probably 6-12 hours of work depending on how skilled you are, how often you mess up and how much you care about getting it to look perfect.
I followed this write up: https://www.evolutionm.net/forums/sh...d.php?t=185913
but there were allot of things that I still had to figure out or change as I went along. I used the exact paints he specified and it worked perfectly. Remove the front bumper. It took me a while to find the last 2 bolts that hold the front on, in the corners of the intercooler mesh area, in the upper right and left corners.
baking is pretty easy, just make sure you have a wet towel underneath the headlamp so nothing burns. The hardest part of the entire project is separating the casing once its out of the oven. The stuff they seal it with from the factory is there to stay, forget about cleaning it all off. Use flat blade screw drivers or thick butter knives to just break the seal, DONT pry up on the casing, it breaks/cracks easily, just apply a little pressure upwards to keep the parts youve gone over from re-sealing. The stuff sticks to everything when hot, so try not to get it on things. Brake clean will clean off light amounts of it, but you need Goop-off in large amounts to really clean the prying tools afterwards. Try and get them apart fast, as it will cool down quickly and become a total PITA to separate at all after about 7-8 minutes.
If you have a car like mine (no fog lights, no factory HID's) then when sanding and painting you will have that little 'imitation' projector sphere in there. Mask him off with blue painters tape very well and try and keep alcohol or anything else off of it, also be very careful when sanding anywhere near it. I also masked off both reflector areas, the area underneath the turn signal amber and the chrome 'eye liner' area. I think it looks waaay better with that still chrome to contrast it. Heres some pics of how it turned out.
You will most likely need to put a new layer of tape on after sanding before painting. The other thing I did totally different was I re-used the factory sealant + some extra silicone seal. Just re-bake the headlight glass and back housing for a few minutes (5-8) and quickly put the painted reflector back in, put a light bead of silicone on, and press them back together. The hot factory sealant will re-seal better than just silicone ever could. (and it was way easier) Re-install was a breeze for me. I didn't have to readjust anything as I re-installed the headlights without messing with the adjusting stuff on the back (other than removing the rubber parts for baking) You can check your headlight level though by parking on level ground 15-20 ft from a wall and checking to make sure they don't go too high (above waist level is too high) or point up at all.
This mod should be required on all white evo 8's, it looks amazing. Hope this helps!
Old Aug 11, 2007 | 05:23 AM
LayinLo's Avatar
Tails
Headlights
You can thank me later.
Old Aug 11, 2007 | 05:25 AM
slicedbreadno2's Avatar
EvoDave FTW
Old Aug 11, 2007 | 06:04 AM
scotdw6's Avatar
what's EvoDave's general turnround time--curious how long I'll be without lights.
