Pic Request: AMS 35r
Old Nov 12, 2007 | 12:02 AM
JdmRoots's Avatar
Hey guys i'd like to see how your AMS 35r evo's have their manifold/wastegates setup.
Please and Thank you.
Old Nov 12, 2007 | 12:13 AM
TeKiZeRo's Avatar
Did you try searching for the pictures?
Old Nov 12, 2007 | 12:14 AM
riceball777's Avatar
they do not put the wastegate flange on the manifold.
they put the wastegate on the 02 housing.
This means that you are required to run a t3 5 bolt turbo housing with the internal wastegate option
you cant run standard gt35r 4 bolt housings. you cant run gt 4 bolt turbo housings. you cant run v bacd turbo housings.
you cant even run standard precision 5 bolt housings because most dont have the internal wastegate option
btw its a great kit that makes great power. i just hate how the waste gate location limites the turbo housing you have to run
Old Nov 12, 2007 | 03:22 PM
JdmRoots's Avatar
appreciated riceball thats exactly what i needed to see!
Old Nov 12, 2007 | 03:45 PM
AutoMotoSports's Avatar
We run it here to control boost efficiently and it works very well. Where other kits have to use a larger 40 or 44 to keep boost at bay the small 38mm works perfect on our kit.
Also the 5 bolt housing that we use isnt just something that we picked out of a hat. we tested every possibly housing for each turbo before settling on the one that we feel offered the best compromise between HP and Spool. The results speak for themselves. This exact setup has gone 9's on just this 5 bolt 35R.
Eric
