Official ADVAN Wheels Thread - RCII, RG, RGII, RS, TCII, Kreuzer, etc
#708
#714
Hello,
Need advise from you guys on Advan RS 17x9 +22 offset. Will they be okay on stock body and 235/45/17 AD08R's? Or will they rub in front or rear? Also will they need any spacer or not for front or rears?
Also does the +22 have the concave face to it?
Car is a graphite grey EVO 8 MR (JDM).
Your input will be much appreciated.
Thanks!
Thanks!
#715
Hello,
Thanks!
Thanks!
#716
Hello,
Thanks!
Thanks!
+22 is not an easy offset to fit correctly. 2 things help in this case, the 9" wheel & the 235 tire
This setup will need a nice tight rear fender roll. Keep in mind, any rear rub is not acceptable. So ride height should not be taken into account. Either it rubs or it doesnt
Any wider tire (i.e. 255/40) this will need a fender pull & a rear bumper bolt relocate to fit correctly
#718
Just picked up some used RGII's for track days, 18x10 +35 with Maxxis RC-1 in 265/35 .. Pulled the rear fender and rolled, no spacer. Fronts i did the fender mod just in case and had to use the big hammer on the frame rail as it was rubbing the tire on full lock.
#719
Not fitted yet but got these badboys to go on mine when it returns from the bodyshop
Advan RS-DF 18 x 10.5j et15 with AD08R 285 30 rubber
http://myprintscreen.com/s/mxps/828f60aabf
#720
Seems like all the +29 stuff is gone now, only +31 and +35 and up. Is this due to demand, or are these still GT-R face wheels with a slightly more fender friendly fitment?
