Pic Request: The pesky 4th gauge.
Old Jan 21, 2008 | 09:49 AM
MR Turco's Avatar
I currently have three gauges in the gruppe-s pod. I am looking for suggestions and ideas on where to put a 4th gauge. I've considered putting one on the steering column but i would prefer not to. The forth gauge doesnt match the other three (the three are prosports and 4th would be an AEM uego) so i dont want to add it to the pod and move one of the others. I would like to keep it clean if possible.
Please post pics if possible or feel free to explain some ideas.
Thanks in advance!
Old Jan 21, 2008 | 10:13 AM
wesside's Avatar
Thanks in advance!
I'd just slap it on the steering column, I've got egt on the left and boost on the right
Old Jan 21, 2008 | 10:27 AM
igo4bmx's Avatar
good idea with the velcro!! i have a cup and was worried about drilling into the column cover
Old Jan 21, 2008 | 10:42 AM
UT_Evo's Avatar
Mine came with double sided tape... Velcro would be good too. Steering column is the way to go man. Do it to the right just like Wes' Mine only blocked out if I had a CEL and if I was going over 150... If you do it farther to the right like Wes did then you probably won't block much at all. You could also have a decent shop cut a hole for it in the dash somewhere... We had our A/F meter mounted like that on the left side of the steering wheel in our S2K, nice and flush with the dash.
Old Jan 21, 2008 | 10:45 AM
justboosted02's Avatar
steering column is the best spot IMO
Old Jan 21, 2008 | 10:46 AM
MR Turco's Avatar
I was thinking the ash tray but i couldn't find pics.
Old Jan 21, 2008 | 10:47 AM
zbomb's Avatar
I too thought the steering was the best place. Here's mine
Old Jan 21, 2008 | 10:50 AM
11secEVO7's Avatar
nice setup!
Old Jan 21, 2008 | 10:56 AM
evo8ster's Avatar
zbomb where did you get That pod holder from?
Old Jan 21, 2008 | 05:34 PM
EvoooB's Avatar
ive been wondering the same thing. im going to have to get another gauge and im not a big fan the gauges on the A pillar and the steering column. has anyone seen or installed a gauge in the vent on either side of the gauge cluster? just an idea?
Old Jan 21, 2008 | 05:43 PM
EVOlution561's Avatar
steering columb would be ideal.
Old Jan 21, 2008 | 06:02 PM
Laxman's Avatar
I just bit the bullet and went to a 5 gauge setup with two on the A-pillar. But then I wanted a little more information anyways
Old Jan 21, 2008 | 06:21 PM
chaotichoax's Avatar
bump for other ideas
Old Jan 21, 2008 | 06:37 PM
Ultimate CC's Avatar
steering wheel with strong 3m double sided tape...
Old Jan 21, 2008 | 06:48 PM
brian250f's Avatar
i was looking thru some threads yesterday and i saw one to the left of the gauge cluster the side mirror adjuster/ acd button is.. ill try to find it if someone else doesnt post it up
