Pic Request: headlight + front bumper
Old Jun 12, 2008 | 08:31 PM
fugiwara's Avatar
ttt, anyone?
Old Aug 7, 2008 | 05:28 PM
fugiwara's Avatar
bump for help
Old Aug 7, 2008 | 05:37 PM
jkim2001's Avatar
so is the rubber gasket supposed to be around the headlight? Gotta check mine to see if its there
Old Aug 8, 2008 | 09:35 AM
fugiwara's Avatar
help still needed
Old Sep 7, 2008 | 02:03 PM
fugiwara's Avatar
i took my bumper off twice and adjusted the tabs still don't work, help...
Old Sep 7, 2008 | 10:07 PM
05EvoVIII's Avatar
here is mine when i got the car is was never this bad but i have had my bumper off ALOT n it looks like this now. it dont bother me that much but ima fix it.
Old Sep 7, 2008 | 10:28 PM
NMFDChris's Avatar
Old Sep 25, 2008 | 02:04 AM
fugiwara's Avatar
the above 2 are pretty bad... anyone has solution?
Old Sep 25, 2008 | 10:50 AM
joon82's Avatar
same problem here. really hate the gap.
Old Sep 25, 2008 | 12:24 PM
fugiwara's Avatar
it's a common problem for evo that had bumper removed
Old Sep 25, 2008 | 01:35 PM
Evo9Fanatic's Avatar
Ya I got the same problem as well.
Old Oct 9, 2008 | 03:28 AM
fugiwara's Avatar
bump
Old Dec 28, 2008 | 10:30 PM
fugiwara's Avatar
Originally Posted by Hittman
^^they probably already fixed the problem there are two metal (soft metal) tabs protrudin from the actual bumper, if you bend them then there will not be any gap b/w the headlights and the bumper
I have tried to bend the metal tabs upward on the side with bigger gap and it didn't help and if I bend too much it will mess up the screws alignments between bumper beam and chasis, should I bend it downward a litte?
Old Dec 28, 2008 | 10:57 PM
CR7-Style's Avatar
i have same problem! you can see these lil rivets on the bumper with the gap, and before you couldnt see them. lame!!!!! i need a fix for these
Old Dec 28, 2008 | 11:08 PM
scorke's Avatar
Scorke
