Trunk battery is in
Old Apr 6, 2008 | 11:02 AM
krazirob's Avatar
Trunk battery is in
Finally found the little bit of time to get my battery relocated.............
and now i got so much more room for something i havent figured out yet..........LOL
Old Apr 6, 2008 | 04:55 PM
Jspec EVO VIII's Avatar
Got a write up anywhere for this? I'm interested in doing this myself. Clean install.
Old Apr 6, 2008 | 05:03 PM
EvolvedGTI's Avatar
What did you do with the positive and negative wires? I can't tell by your pics
Old Apr 6, 2008 | 05:11 PM
dedlewamp's Avatar
Yeah, I would be curious to see that as well. Did you use a fuse block of some sort?
Old Apr 6, 2008 | 05:14 PM
Roldy's Avatar
Put a oil catch tank in there now.
Old Apr 6, 2008 | 05:27 PM
krazirob's Avatar
if you are referring to the engine bay there is already one in there....
Old Apr 6, 2008 | 05:31 PM
krazirob's Avatar
i bought a 4 guage amp kit that came with a 17ft inline fuse cable and a 3 foot negative cable.
ran the positive cable all the way to the front and connected it to the 3 cables that i took off the terminal under the hood. as far as the negative cable i just grounded it inside the trunk right next to the rear windshield washer resovoir.
there are many ways to do this, mine was a average priced project. most expensive thing was the battery......lol
bought some digital terminals tonight so i will be putting those on soon. i was gonna use the stock terminals but the negative wouldnt come off so i bought two matching ones from autozone for temporary purposes......
Old Apr 6, 2008 | 06:57 PM
RAbishi's Avatar
Clean install. Nice work.
Old Apr 6, 2008 | 08:43 PM
importjake00's Avatar
how much did this cost you over all?
Old Apr 6, 2008 | 08:49 PM
krazirob's Avatar
----BATTERY- 150
----TERMINALS-20
----CABLE (AMP KIT) 30 BUT YOU CAN JUST BUY SOME CABLE AT A SOUND SHOP CHEAPER
----BATTERY TRAY - 20 BUCKS
thats basically it.............and just a little bit of time and patience running the wire and tryin to make it look clean will get ya going.........
If you arent buying the optima then it can be very very cheap. but these batteries are vibration resistent and i have the pro sevens on which is a harder ride then stock so it can be quite bumpy.......lol
Old Apr 6, 2008 | 08:53 PM
ObsessionByEvo9's Avatar
Twin turbo perhaps? lol. Looks great!
Old Apr 6, 2008 | 08:55 PM
krazirob's Avatar
i wish.....can you imagine the lag with those
Old Apr 6, 2008 | 10:08 PM
Mistaken's Avatar
Looks great! Good job
Old Apr 8, 2008 | 01:40 AM
dannys EVO IX's Avatar
cool!
how did you connected the stock terminals to the wires?
how did you ran the cables, inside outside?
Old Apr 8, 2008 | 01:43 AM
krazirob's Avatar
bolted them together through the eyelids after i removed them from the stock terminal. and ran the cable under the car outside..
