View Poll Results: What lip should i buy?
Rexpeed CF RA style
49
52.69%
JDP CF RA style
33
35.48%
Other
11
11.83%
Voters: 93. You may not vote on this poll
Poll: Rexpeed vs. JDP Evo IX lip
I don't know if this one is any different but i got the JDP SE lip and you can't attach the undertray as there are no tabs like on the stock one. Fit was good, but finish was a little lacking. I will probably replace it with something else. Don't know about anyone else but this was my experience.
you need the mitsubishi lip extension that comes with the SE's it fills in the space between the lip and the under tray. this is what the "anti lift" kit is.
and good choice goin with JDP!
No. The "anti-lift kit" is the lip underneath the front of the MR and the Gurney flap on the wing. For the SE Lip there are extensions, it consists of three panels. Contact RussellM (awesome service), that's where I got mine and ask for the SE lip panels. Make sure you don't say anti-lift as it's completely different. As for the JDP lip, I'm pretty sure e means it doesn't have the holes on the bottom of the lip like the SE lip to attach these three panels he needs. I'm pretty sure he doesn't want to ruin his lip by drilling it for the holes he needs for the panels to be riveted, to work with the undertray.
Here's a pic to help understand. The black pieces are what you need to attach to your undertray. There's two on the left, one on the right. The holes on the SE lip are where they should be on your JDP, so the black panels can attach, which then attach to your undertray (rivet them).
those three panels and part# MZ380342EX-MZ575625EX makes up the "zero lift kit."
but yes you need thoose three panels to run a under tray with this lip. other wise it will line up like this:
sorry for my miss use of the word anti and or zero
