Pics of the build in the garage!!!!! 56k no no
Old May 16, 2008 | 08:27 PM
SpunEvoIX's Avatar
Old May 16, 2008 | 08:28 PM
BocaShula's Avatar
thats insane
Old May 16, 2008 | 08:46 PM
Evo9"Miss Rose"'s Avatar
^^^+1 good luck on the rebuild.. i feel your going to be happy when all is finish!
Old May 16, 2008 | 08:50 PM
SpunEvoIX's Avatar
Old May 16, 2008 | 09:08 PM
FLOW1's Avatar
Good luck.
Old May 16, 2008 | 09:13 PM
BBS's Avatar
BBS
I like how your username coincides with you "spinning" your rod bearings
Old May 16, 2008 | 09:23 PM
SpunEvoIX's Avatar
lol i had a diff username but it was seriously wack so y not spun!!!!
Old May 16, 2008 | 09:38 PM
PainInMySide's Avatar
Good luck with the rebuild
Old May 16, 2008 | 09:39 PM
SpunEvoIX's Avatar
Old May 17, 2008 | 10:35 AM
andreww238's Avatar
nice... good luck with the build
Old May 17, 2008 | 11:07 AM
TalonTuner4G63's Avatar
First off, what kind of "crappy oil" did you use to do this? How do you know it was contributed to the oil?
Second, looking at the pictures you posted, I see you have not had any machine work done, you just scuffed up the deck of the block with a 3M pad and ran a ball hone down the bores. The deck wouldn't be such a big deal had you chosen to run a composite gasket, but I see you are using a metal job. Spraying it down with copper spray (which you did) is not a sure-fire way to make it seal, unless the block is re-decked at a machine shop. Did you even check the deck with a machinist's straight edge?
Old May 17, 2008 | 11:09 AM
SpunEvoIX's Avatar
i had some quaker gay and everyone noes that oil is sh***y and basically 1000 miles over my oil change i spun the bearing in normal driving conditions... on top of that the oil came out black and was not thick at all wen it came out at the 1000 mile mark
Old May 17, 2008 | 03:48 PM
sonicteam120's Avatar
ouch how much longer you think you going to be down
Old May 17, 2008 | 03:55 PM
zbomb's Avatar
I like the way you roll man! Big up's to a build done the hard way.
Old May 17, 2008 | 04:04 PM
1131's Avatar
props on doing it the hard way haha
