C/F trunks with wings...
Old Aug 22, 2008 | 04:23 PM
QwikEVO's Avatar
Howd you drill your holes for your wing?
I'm debating this, but I'm really apprehensive about drilling my expensive lid and fubar'ing it up.
Old Aug 23, 2008 | 06:47 AM
1NastyMR's Avatar
I would say don't even put the wing back in drilling holes is risky if do it wrong you could mess up your the carbon
Old Aug 23, 2008 | 06:59 AM
Silver06evo9mr's Avatar
make a template from your stock hood
Old Aug 23, 2008 | 07:00 AM
also drill a small hole to start with and work you way up to the size you need so u wont crack it.
Old Aug 23, 2008 | 07:11 AM
Fairclough's Avatar
If you can access the back of were you are going to drill, use a piece of wood to apply slight pressure this helps prevent cracking.
Old Aug 23, 2008 | 09:05 AM
n1nj4 m0d3's Avatar
unless there's a support underneath the trunk where the wing mounts onto, i would not mount anything on cf
Old Aug 24, 2008 | 08:16 AM
MasterNater's Avatar
I used a sanding cone on a dremel, like the one pictured here on the far left. I used the cone to start a pilot hole and then used a drill bit afterwards. The advantage of using the cone was that it sanded away the layers, rather then tearing it away like a regular drill bit would. I also started with very small drill bits and gradually went bigger. It may have took a little while to complete, but I don't have any splits or cracks in the trunk.
Old Aug 24, 2008 | 08:21 AM
Q@EvoPowerMods's Avatar
Be sure to put a metal backing plate on the underneath side with your mounting bolts drilled through the plate..to aide in strength. The wing will cause lots of force and pressure. Carbn Fiber is extrmely stong however it dooes have it's limitations. But if you put the backer plate which the bolts drilled thrpough this aluminum plate then you shouldn't have any problems. Hope this helps..
Old Aug 25, 2008 | 09:31 PM
kuo246's Avatar
very slowly!! =)
Old Aug 25, 2008 | 10:34 PM
PANGES's Avatar
If you drill/dremel. Make sure you put some painters tape on the area you're going to start drilling on so the drill bit doesn't move/get out of control and scrape up the clear coat. I learn this from personal experience drilling holes in my CF hood for hood pins on my 240sx.
Old Aug 27, 2008 | 02:15 AM
QwikEVO's Avatar
anyone got pics?
Old Aug 27, 2008 | 02:21 AM
Cali2MDevo8's Avatar
Registered User
I don't know if I would do it personally.
I drilled my JDP CF lip on 2 days ago to use the stock screws and on 2 of the holes, it started to break apart in the back after putting in the stock screws.
Old Aug 27, 2008 | 07:35 AM
That's because you didnt have backer plates, on Carbon Fiber it is a must..!..
Old Aug 27, 2008 | 08:01 AM
evolutionEvo's Avatar
i just drilled the holes straight up with zero issue.....
Old Aug 27, 2008 | 08:11 AM
evo_q8's Avatar
^^^^^ Loooks amazing! Job well done
