My JDM EVO IV
#289
got some rather worn stocko pads on it atm, just took it for a lap around the block, once they settled in my first impressions are it pulls up harder with less pedal effort.
took a bit of fiddling to get em to sit nice, had to move the backing plates as it made them sit wrong, but all good now.
Going to get some other 2nd hand pads this weekend with a bit more meat on em, but yeah very happy
#290
6 point cage fitted
had to remove A pillar trims so put the gauges down near the shifter
got some Hankook Z221 softs for the Nats coming up in August
have fitted a Turbosmart actuator which holds boost a lot better that the original one
have got the boost pretty well sorted now, turbo failed some time ago and is running fine with the HD thrust now fitted to it, now also running United E85 pump fuel
3rd gear VDR run
3rd gear VDR run
#291
made it to the local track, Queensland Raceway for a sprint session, was pouring down rain early in the morning and for the first session so it was a bit skatey, the wing was working awesome, by the 3rd a half decent dry line was developing and by then I had first outright for the day, last session 2nd lap my motor cried enough and kicked a rod out (SCAT H beam) and caught fire so luckily I put my extinguishers to good use and saved the car from a fiery death, my mate pipped me at the line by 3 tenths so 2nd outright (39 entrants) was the result, so anyway next motor will be a 2.4 with,
MAGNUS I beam long rods
WISECO HD pistons
OEM crank
GSC R2 cams and springs
GTPumps 762 turbo
5ltr surge tank with twin 044 pumps
in the wet, and doing a bit of off road
motor KO
2.4 purchased
stripped and setting up block, breather fitted
new turbo
pic from GTPumps
WISECO HD pistons
OEM crank
GTPumps 762 turbo
motor KO
2.4 purchased
new turbo
pic from GTPumps
#293
upgrading all the fuel system etc to support the 2.4
5ltr surge and twin 044
PLAZMAMAN LICP
ported the outlet to match the turbo
AN-10 fuel line to front, will split to 2x-6 to the fuel rail
trial fitting the parts
motor will have
GSC R2 cams w/ 5041 springs
Kiggly HLA
WISECO 9:1 HD pistons
MAGNUS 156mm I beam steel rods
triple crank scraper
RACE FAB sump
GTPumps 762GTP turbo
FULL RACE manifold
will be running on E85 2 tunes at 26/35psi should go about 550-600whp on 35psi
PLAZMAMAN LICP
motor will have
Kiggly HLA
RACE FAB sump
FULL RACE manifold
#297
Nice one, those magnus (R&R) I beams look great, should hold up well. Going to be very quick with that much power in such a light car. Hope I can see it in action at the next nats
#298
yeah that is the plan, hoping to do a few time attack days prior to get it fully dialed in, it certainly went well at QR so hopefully handling wise it is nearly there, it is not that light either 1340kgs with the cage and me in it
#300
