Rexpeed VIII Front Splitter...
Old Feb 21, 2009 | 03:29 PM
RichC's Avatar
Quick question that I haven't been able to figure out...
How much lower is the Rexpeed splitter (http://www.rexpeed.net/new2007/produ....php?serial=93) as compared to the stock one? As it sits, my stock lip meets the bumper at 6.5" of ground clearance, with the lip itself at 5 1/4" of clearance.
From pics, it looks to be 1-2" lower.....
Old Feb 21, 2009 | 03:39 PM
tougetuned's Avatar
let me go measure mine for you, im on stock suspension, be back in a sec.
Old Feb 21, 2009 | 03:44 PM
tougetuned's Avatar
im parked on an uneven surface but it measures 6.5 inches off the ground from the bottom center of the lip to the ground hope this helps
Old Feb 21, 2009 | 03:55 PM
RichC's Avatar
thanks man, can you measure the actual width of the lip? since i'm pretty low on coil-overs, i think that would be the best way to judge.
Old Feb 21, 2009 | 04:10 PM
tougetuned's Avatar
the actual lip itself is approximately 3.25"
EDIT: i forgot to mention i have the do-luck style, the varis style one might be a little lower to the ground toward the corners
