Fender Rolling FTW!
Old Mar 15, 2009 | 03:55 PM
vegasboy301's Avatar
Originally Posted by wesside
+1
yo wesside whats up man!
Old Mar 15, 2009 | 07:13 PM
kaymin's Avatar
hold on, whats the difference between flaring and pulling?
and dave I totally didn't understand what you meant about the cave in thing till I went a little further today and it's got a fatty bulge above where the rear bumper mounts on both sides.
guess it's time for a widebody
Old Mar 15, 2009 | 07:40 PM
Paulito's Avatar
pulling involves body work and you can either leave the body line or take it out. I did this on my past vw and widened the arches over an inch. flaring is basically just causing the vertical body line to be on an angle, thus flaring.
The buldge you're talking about isnt the one dave is i believe. You flared yours and now thats your hard line basically because you cant flare the pinch without cutting... The buldge dave is speaking of i believe is when you over flare the fender it causes the metal above the arch to push in causing an inward dent because your pushing the metal upwards and exerting the force and it has to go some where.
Old Mar 15, 2009 | 07:57 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
no you can pull it fairly hard without issue even though its 3 layers of metal.
yes , you can see the area above the flared section is indented.....always happens you have to put initial angle on the roller like this \ then as you go get it straight up and down like
this | to pull it and not flare it. most people do it like they do with 240s with a serious angle which is what you need to do only to get it started on an evo
Old Mar 15, 2009 | 09:19 PM
kaymin's Avatar
that's what I did at first till the roller was maxing out. I didn't know how that you could move the pin on it to get more travel... One fender was already done like that so I had to do them both the same.
Old Mar 15, 2009 | 09:21 PM
evodave's Avatar
yep you have to switch the pin to allow more travel
Old Mar 15, 2009 | 09:22 PM
kaymin's Avatar
hahah and now we know
It still looks decent. The fronts are too small to even use the roller on.
Old Mar 15, 2009 | 09:34 PM
evodave's Avatar
here is the setup i just did on my evo race car i am finishing.... btw its way to low i raised the car and honestly the camber wasn't in much at all .....it will be running more camber then pictured
Old Mar 15, 2009 | 09:35 PM
evodave's Avatar
no don't use the roller on the front i have a kit available now i am going to make a thread for tonight
Old Mar 15, 2009 | 09:36 PM
kaymin's Avatar
i just heated hammered then slightly rolled the fronts.
What's this kit consist of?
and what's the specs on those wheels? They look ALOT like what I have
Old Mar 15, 2009 | 09:38 PM
evodave's Avatar
i used a blue fender to show a good view of the mod
front to show it still meets up perfectly
Old Mar 15, 2009 | 09:39 PM
evodave's Avatar
oh and btw the crazy thing is this already makes the wheels/tires clear with almost no camber.....even a street evo should run at least -1.8 camber and race cars will run -2.7 degrees
Old Mar 15, 2009 | 09:40 PM
kaymin's Avatar
ohh! I plan on doing that too if the wheels rub with the itty bitty roll I did.
How much is your kit?
hanahawaiian's Avatar
dang dave, it look sick!
Old Mar 15, 2009 | 09:42 PM
evodave's Avatar
$70 shipped for the kit
and it can be reversed
