engine cosmetics
Old Sep 30, 2003 | 12:30 PM
evolutionist's Avatar
Originally posted by kdogg
Funny guy, just noticed the pic was horizontally flipped. I thought is was a RHD 8 or something.
No, just my inexperince of jpegs. Still learning the ropes on editing the pics.
Yeah, I think they spell the Mitsubishi name backwards on the RHD.
Old Oct 1, 2003 | 12:10 AM
vicbdn's Avatar
I like, where you get those yellow thingies. I think maybe all red woulda looked a bit better, but i guess you cant do that with the HKS intake.
Old Oct 1, 2003 | 12:13 AM
ryancb's Avatar
not bad but i am not a fan of yellow
Old Oct 1, 2003 | 03:54 AM
I did not start out with yellow in mind. It just kind of happened. The good news is it is only $15.00 in vacume lines. You could change the color in about half an hour. The red of the valve cover is hard to match. So I went with the yellow battery and the filter of the HKS is also already yellow. Who knows the lines may be some other color in a month if I get restless. Thanks for the reply.
Old Oct 1, 2003 | 03:56 AM
You can get the lines at any import car store. They have about any color you want. Just make sure you replace the lines with the correct mm size. You don't want the line to come off.
Old Oct 1, 2003 | 05:08 AM
jotan82's Avatar
you painted the heat sheila brite red
Old Oct 1, 2003 | 05:16 AM
93civEJ1's Avatar
looks like under the hood of F&F, colorful..... kool deal man. To each their own. I am not a fan of the wire loom, other that, kool!
Old Oct 2, 2003 | 11:55 AM
LancerXtreme's Avatar
Where did you get the two parts (the one that connect to the Negative and Positive Parts of the Battery). Been looking to replace mines so I dont have to bent one of them to make them fit. Plus, they look a lot better.
Old Oct 2, 2003 | 12:40 PM
Those are gold plated battery terminals. They are made by Tsunami. I got them at AutoZone. I have seen them at tuning shops and other part stores. Both terminal ends have two ports, one for the pos or neg cable and one for an accessary if you need it.
Here is a pic with some more detail.
Gary 805
Nov 1, 2020 08:43 AM
RnR Racing
79
May 21, 2006 10:07 AM
Derek888
Jan 13, 2005 04:09 AM
DriftRunSir
Dec 15, 2003 06:15 AM
m_allard
Mar 5, 2002 01:41 AM
