Test Fit 18x10.5+22 Volk te37
I got them for my wide body sti and was going to go 305s. The motor is out of the car right now so I thought I would use these on my evo until I get new wheels an tires for it sometime this summer. Right now the wheels are mounted on 275 toyo r888. The rears will be pulled and flared which will fit 275 but I need some coil overs to run the 275 on the fronts probably. However these wheels give me a great excuse to buy some coilovers right???!
With the difference in offset and the rpf1 having 285s on them i would guess its probably 1/2 wider than my set up as it sits. Me putting 265 on my te37 might stretch a little bit for the time being but when i get a 10 inch wheel the 265s will fit perfect and i can say i did not burn through my toyo r888 driving to work and back. I would guess that my 10.5+22 te37 with 265 vs 10.5+15 rpf1 with 285 is about 3/4 inch diference which is a ton when your talking agressive fitment to begin with.
I bet you have about 8mm of clearance between your wheel and your trailing link in the rear.
Thank you for posting, I was curious how the +22 would fit in the rear. The fronts will clear like butter, but the rear looks as I suspected... can you measure the distance from the tire to the quarter and guestimate what camber you're running in the rear currently?
