BBS wheel spacer
Old May 16, 2010 | 10:42 PM
B-rent's Avatar
BBS wheel spacer
hello everyone, I just installed a set of swift type-r springs on my bilsteins to drop my 8 and give her a more aggressive stance. I also want to flush up my MR BBS wheels to complete to look. what spacers sizes front and rear would give a flush look with my BBS and 245/40/17?
Old May 17, 2010 | 04:53 AM
BEISSEN's Avatar
I think its a 5mm or 10mm spacer to flush it.
Old May 17, 2010 | 06:26 AM
CJ2X's Avatar
I'm thinking it would have to be a bigger spacer to "flush". Atleast a 15mm...
Old May 17, 2010 | 06:27 AM
CJ2X's Avatar
I will warn you that spacers are heavy..
Old May 17, 2010 | 08:38 AM
jdmEviL8's Avatar
on old picture with 20mm spacers with 255/40 they stuck out a little much and did rub in the back. Just a little something to help you with your decision
Old May 17, 2010 | 11:07 AM
B-rent's Avatar
^ does this car have 20mm both in front and back? Thanks for the feed back guys
Old May 17, 2010 | 01:25 PM
BEISSEN's Avatar
Yup.
Old May 17, 2010 | 01:44 PM
BBS's Avatar
BBS
Did you get extended studs for the 20mm?
Old May 18, 2010 | 07:40 PM
jtyler's Avatar
I'm curious as well..
Old May 18, 2010 | 10:25 PM
lznk41's Avatar
im running project kics 20mm spacers in the front and rear on stock gsr suspension with white oem bbs wheels (the spacers have extended studs built into them) going over to coilovers this summer. the rears will definitely rub, but only a roll is required. the fronts will need just a tad bit of negative camber.
im also running advan neova ad07 245/40/17
Old Aug 10, 2010 | 02:17 AM
evobros's Avatar
looks good
Old Aug 10, 2010 | 08:43 AM
fqjdmct9a's Avatar
anymore pics?
Old Aug 10, 2010 | 10:59 AM
Gigsohard's Avatar
i would say a 15 evobros
Old Aug 11, 2010 | 01:41 AM
evobros's Avatar
yup
wowzers
20
Feb 9, 2016 06:08 PM
ilviolatorli
Dec 22, 2015 10:13 AM
smithrcing17
Oct 2, 2010 07:30 PM
soontobe
Aug 28, 2009 02:56 PM
tlr9
Feb 27, 2009 08:42 PM
