picture of my bushur racing filter need help
Old Jul 15, 2010 | 10:56 AM
Tommy_Lee's Avatar
I just finished installing the buschur racing air filter kit for the evo and I was wondering where you guys installed your L shape mount for the filter. I had one on but after a test drive it became loose so i decided to take it off and let it rest in the bay without one. heres a picture of how it sits right now, thanks in advance.
Old Jul 15, 2010 | 11:24 AM
Svendiesel's Avatar
L shape mount
Old Jul 15, 2010 | 11:34 AM
EvoFredo's Avatar
haha ^^ yeah. i dont remember ever getting a mounting braket. to the op Post a pic of it. or use some of your ceative talent and find it a home.
Old Jul 15, 2010 | 12:01 PM
Tommy_Lee's Avatar
lol sorry here is the picture of the L shape mount i was talking about... i talked to dan@buschur racing he said it was fine what do you guys think?
Old Jul 15, 2010 | 12:09 PM
apagan01's Avatar
i had mounted mine where the OEM boost controller BCS is bolted onto the chassis, and i even kept the BCS instaled together with the L braket.
Old Jul 15, 2010 | 12:55 PM
RevMoto's Avatar
your maf should be tilted where the flat part is on the top where it plugs into the harness. The L-bracket should be connected to one of the bottom bolts on the maf and to the bolt the held the stock bcs as stated above. From what I have hear if you just left it loose without the bracket you can cause false knock from it bouncing around.
Old Jul 15, 2010 | 01:00 PM
XxApollynxX's Avatar
Are all the intakes supposed to have a support on them? Because all the ones I see locally sure dont.
Old Jul 15, 2010 | 02:04 PM
Svendiesel's Avatar
Maybe its for the stock intake tube only?? I know mine didnt ever have an L bracket, but I have the BR intake pipe. The stock intake tube is floppy and sags, maybe that bracket keeps it off of something and must support it.
Old Jul 15, 2010 | 02:07 PM
tarmac03's Avatar
you should rotate ur maf so that the sensor is on the top. also u need to modify that bracket to fit.it will go on the bottom rear air filter adapter bolt and then to a bolt hole that was used to mount the stock air box on the top of the frame rail.
Old Jul 15, 2010 | 02:10 PM
tarmac03's Avatar
also i think the longer side is the side that bolts to the air filter. hope this helps
Old Jul 15, 2010 | 03:40 PM
ev0lution9's Avatar
i remember when i installed mine it was a pain to fit but you just gotta move it around and figure it out your MAF sensor should be tilted up so u can see the top of it
