View Poll Results: Headliner choice
Voters: 143. You may not vote on this poll
Ultimate JDM Metallic Jade Green IX MR build
As I was running the remaining wires to the other side of the tray (ACD pump & mass air) I noticed at the the end was a 2"+ drain hole that ran out the side!! And they make it easy enough that I can run down the fender rail undetected. The wires need to be extended as with most but everything is almost laid out.
Interesting.. Hope it works out the way your bringing it.. I was going to go with a cannon plug style. much smoother and if your good with wires and know how to you a red and white, have the crimping tools and pins etc.. you will be set.
http://i28.photobucket.com/albums/c2...e05/canon2.jpg
Did not want to jack your thread so i left the [img] codes out. I just think if you were to keep it separated from bay/cabin it would limit the amount of long term headaches.
EDIT:
If your not in the military and able to access the Pre-X or publications then here is some info if you chose to go this route.
http://www.p-r-s.com/Catalog%202007/...Connectors.pdf
http://www.peigenesis.com/connectors...html#series1-2
EDIT:
so sick evilT Im lovin this thread. Looks like you do great work.
I have a question though. I don't want to hijack, but I'm thinking about redoing my car. I was thinking about goin flat white, with a lil candy/pearl in it. Just wondering what you think, seems you have good taste.
Keep up the awesome work and good luck with everything.
Buddy
Buddy
Thanks to all for the support!
I spent 2 hours just linking pieces, I have atleast 8 more hours in connections still needed... As always I'll post up pics tomarrow night, blazin headache need a break.
