Herra Frush y0!
Old Feb 27, 2011 | 08:51 PM
  #31
Kidloco51's Avatar
Rad.
Old Feb 27, 2011 | 08:59 PM
  #32
limp_noodle's Avatar
hey look, someone who has the right sized tire on they're wide wheels.
I like it man.
Old Feb 27, 2011 | 09:20 PM
  #33
R/TErnie's Avatar
Ok,
I'm getting some shorter springs up front and probably some matched rate springs for the rear. I'll run just a little more rate than the Ohlins came from standard. Nucci showed me some 65mm springs that I can run on the 2.5" perches.
I'll be ordering the Chromoly for the trailing links and measuring the ball joints this week.
I'll have to coax my friend with a lathe to make some pieces for me so I use the OEM link to chassis ES bushing and the aftermarket Ball Joint.
My metal working friend Jason Hoskings will be coming over for some custom bits. So I wouldn't say it's completely stock lol.
Old Feb 27, 2011 | 09:46 PM
  #34
ToxicFab's Avatar
You havnt mentioned offset yet? +18 right? I'm on work xt7 18x9.5 +22. To flush lol looks great Eric, now roll the Hell outa the rears
Old Feb 27, 2011 | 11:10 PM
  #35
R/TErnie's Avatar
+38s
20mm spacer up front, no spacer in the rear. I might be able to use an 18mm front spacer or a 19mm spacer to save a few mm's. Caliper clearance is about 4-6mm.
Old Feb 27, 2011 | 11:56 PM
  #36
BenJ's Avatar
That is an awesome setup for sure...loving the 295's! It is also cool that you are able to get away with a 18-20mm spacer. My 18x10 +38 XD9's are requiring a minimum of a 25mm spacer which is only netting me 1mm of clearance at one point on the caliper by the piston. Sad face lol but it will be fine.
Old Feb 28, 2011 | 06:31 AM
  #37
Go_Lancer_Go's Avatar
So with this setup, will ur handling goto ****?
Old Feb 28, 2011 | 07:12 AM
  #38
FLOW1's Avatar
Nice 295!
Old Feb 28, 2011 | 07:33 AM
  #39
goad_white03's Avatar
looks good eric!
Old Feb 28, 2011 | 07:42 AM
  #40
sho669's Avatar
It's a track/autocross setup...why do you think having more traction would make handling suffer?
Turning radius maybe but handling
Old Feb 28, 2011 | 09:50 AM
  #41
analogEvo's Avatar
Turning radius is bad already so when one runs big *** tires you will lose some turning.
You will mos def stick to the track lol but may cause some understeer.Sick setup tho
Old Feb 28, 2011 | 11:06 AM
  #42
jid2's Avatar
Originally Posted by R/TErnie
Ok,
In a month or two I'll be ready to build all sorts of control arms when I finish the CNC conversion of the milling machine I just put in the garage. I can also be a friend with a lathe, got one of those now too.
I'll have to checkout what you did to fit that kinda meat under stockish fenders fo_sho. You coming out to the big track this year?
Old Feb 28, 2011 | 11:38 AM
  #43
revvin9k's Avatar
Wow, flush....and functional FTW!!!
Old Feb 28, 2011 | 12:22 PM
  #44
nucci's Avatar
Based on what I'm hearing, he's taking it far enough apart that its anybody's guess when it will be back on the racetrack...
Matt
Old Feb 28, 2011 | 01:34 PM
  #45
R/TErnie's Avatar
The new engine will be the biggest hold up IMO. New turbo is on the brew
