The "Illest" Evo 8. Photoshoot.
nice ride, love white on apex silver. wanted a similar setup but with a 9" or 9.5". not a fan of stretched tires though.
should edit the first post with the cars spec sheet and wheel spec
Thank you everybody =) It was fun shooting this evo, and seeing it on the highway is nuts, its so low that every bump, i look in the rear view to see if he'd clear behind me!
**added mod list to first post =)
Minimalist approach:
a) You will need to run a minimum of a 25mm spacer up front which will call for either bolt on spacers or extended studs (3").
b) You do not need any spacers out back
c) You will need to run about -3 camber up front and the rears will actually fit 'fairly' well.
d) You will need to roll your fenders all around and relocate the two rear bumper tabs a little further back to clearance the tires.
Realistically-What-You-Should-Do approach:
Same as above, except add the following:
e) Either custom or aftermarket rear trailing arms to clear the wheels tires properly and prevent scrubbing and possible tire blowout.
f) Run a smaller spring (6") to clearance the inside of the tires and the suspension.
g) Run either a wider front fender or the EvoDave kit.
