Jack's Built 35r'd Bby Blue evo 8
9.0:1 would be optimal me thinks for the amount of boost you want to run. or even stock 8.8:1. L19 headstuds would compliment the high cylinder pressure when running higher compression and PSI.
also, some GSC S3 cams, kelford 280/280 or even cossie 280/280 would benefit you better than the HKS' cams.
new compression will be 10:0:1 with buschur 2.0l
