Official "STANCED" Evo Thread
RobiSpec will be offering the custom trailing links that I made for my car soon. They allow the rear wheel/tire combo in the rear to go inboard without rubbing. It gives approximately 1" more clearance than the OEM trailing links. Give Robi a call and reserve your set of trailing arms! www.robispec.com
The front's require the regular rolling, lots of negative camber @ the plates, camber adjustment at the hub (positive), hammering pinch welds flat, etc, AND running a 6" spring up front to clear the wheel/tire in board. Anyone can do it, but it requires that you USE the offset to your advantage and don't waste space inboard.
id love to do 18x10's with like 265's if the smaller tire made it a little easier.
