Relocated my battery to the trunk pics!
If you want the engine bay to look cleaner, theres a plastic tab on the left side of the fuse box on the firewall side. Drill a hole in it and mount a threaded bolt and mount the wires to it directly and secure with a nut. Very clean install BTW.
Thanks for the complients and suggestions. It didnt really cross my mind to place it on passenger side for weight distribution. All the pics that I seen on here had theirs on the driver side or centered. So I may switch it over there. And yes I did cut down the threaded bolts. I know for sure I will switch to 2 guage wire soon. But for some reason after moving my battery to the trunk, my car only boost 18psi.... So now I have to find out why my car is only boosting 18psi now. Seems like its always something. haha.
OP. What did you connect the negative to? I bought 2 gauge wiring and I'm having my buddy make me an aluminum box for it. I've been told the only place to get a real good ground is the block but I'd rather just run it down to my frame or trunk floor. What worked for you?
