Prosports Installed
I read there was a common issue with the oil pressure sensor on some older gauges, but the Halos shouldn't have that problem. We'll see I guess.
i have the stri gauges and love them as well. if you have the egt gauge its a compression type fitting for the probe instead of weld on. best way is to take off the manifold and drill a hole the diamater you need then get the thread feeler gauge out and tap that hole with it. pretty simple
