awesome headlights!!
From: Detroit metro area Michigan/Washington DC metro area
In the process of doing the same to my headlights. One of my boss's said he needed a show piece and offered to do my car since I frequent a lot of the shows to push local sales his way so he's doing the following:
Triple projector headlights, moving the stock projector to the high beam location, bi-xenon Mormoto projectors in the low beam and fog lights. He's going to wire up the low beam fogs to the standard foglight switch and the highbeam fogs to an aux switch so that I can switch it on when hitting up the backroads along with the secondary high beam in the bi-xenon low beam spot. Entire housing it to be painted satin black and he's keeping the headlight adjustment setup as well.
^^ why did your retrofitter leave the shroud chrome when the rest of the headlight is black??
Makes sense to black it out and make the whole appearance look better...
The Mini Gatling Gun shroud in the high beam housing doesn't match the OEM shroud in the low beam housing... It doesn't look right
