umadevo's ultimate track/street monster build
Old Sep 15, 2012 | 12:01 PM
  #46
umadevo's Avatar
So here's some progress as far as the build itself goes. I found a crack in the back of my trans case. Driver's Firewall side of the case.
I've shaved some brackets off the bay. The A/C line brackets on the pass strut tower, the hood prop bracket, also the fuse panel brackets on the dr side strut tower. I'm deleting my ABS so I dont have to deal with all the lines cluttering up the back of my bay, plus I get a slim master cylinder.
Picture time.
As for future plans, I need to get a used case or buy a new OEM one from mitsu. Depending on the price, that will determine whether I just buy a complete used 5 spd. I don't expect anything to be of use in this trans as it was run for about 20 miles with the hole in the case (no fluid). Sucks because I wanted my VIN tags to all match.
I'm finishing up on the engine bay, most of it is all taped up and ready to be sprayed. I'm still deciding on what color to go with. I've got a few ideas in mind. Either a metallic purple, color-matched Wicked White, or Tiffany and Co. Blue. Which ever color I do decide to use, I will end up color-matching my roll cage and rotas/ccw centers to the same color. I'll have more pictures as I continue to change things.
Old Sep 15, 2012 | 01:51 PM
  #47
raysevo's Avatar
Nice
Old Sep 19, 2012 | 11:51 AM
  #48
umadevo's Avatar
trying out colors today. Tell me which you think. Both are purple with metallic flake.
Old Oct 2, 2012 | 05:32 AM
  #49
raysevo's Avatar
#1 or #2 i go for #1
Old Oct 2, 2012 | 06:22 AM
  #50
ILuvJDM's Avatar
that car bed is LEGIT
Old Oct 4, 2012 | 04:59 PM
  #51
umadevo's Avatar
tada.
Old Oct 10, 2012 | 11:00 AM
  #52
umadevo's Avatar
abs deleted
Old Nov 25, 2012 | 12:20 PM
  #53
umadevo's Avatar
First time the bay has seen sunlight
Old Dec 19, 2012 | 08:33 PM
  #54
umadevo's Avatar
Bought Chris Cessna's DoLuck Trunk. Drove out to STM to get it in my s2000. Needless to say, it was tight, but I made it. Thanks again Brian and Justin @STM!
Old Dec 20, 2012 | 11:25 AM
  #55
abazaba410's Avatar
^ I love that trunk. Nice pick up
Old Dec 20, 2012 | 12:04 PM
  #56
whiteEvo08Y's Avatar
What kind of trunk lid is that? Nice build, love the engine bay color
Old Dec 20, 2012 | 08:10 PM
  #57
umadevo's Avatar
Thank you.
It is an Authentic DoLuck carbon fiber trunk. it weighs 13lbs.
Old Dec 29, 2012 | 03:36 PM
  #58
umadevo's Avatar
just a recent picture of it. I'd like to mention that everything you see on the car (trunk, wheels, lugnuts, shorty antenna) all came from STM.
Old Jan 25, 2014 | 06:13 PM
  #59
umadevo's Avatar
Alright so haven't posted here in a while. I've been pretty busy with my new career which has left me limited time to work on this. Finally have some time to play with her a little bit.
I ended up buying a Skunk2 Pro Series Intake Manifold, Ported by Austin at STM paired with a Full Blown 70mm TB and a limited edition satin purple FIC Fuel Rail.
I also picked up an ARDesign Hood Dump, which I've found pretty hard to come across pictures of, so I've provided a few.
Old Jan 29, 2014 | 08:31 PM
  #60
umadevo's Avatar
Goal for today was to dress the new TB and Manifold - Taking the old sensors off was kind of a pain, Especially the IACV. I ended up snapping 2 of the stock bolts and ended up very carefully thumping it off.
As for hardware, I was kind of depressed when I called STM and they told me that the factory bolts for the sensors were $3.50 each. I ended up taking bolt/thread pitch measurements and found them at a parts store local, all 7 bolts for under $1.
Mounted the intake manifold to see how it looks. Not bad.
