2006 Evo 9 Build Thread (Pa) PIC HEAVY
Old Nov 15, 2014 | 05:51 PM
projektevo9's Avatar
Hello guys and gals: I'm finally getting around to writing up my build thread, it's been a long road but it's finally finished. I’ve had this car since July 16th, 2011. I purchased the car off of a gentleman in his early 30’s back in 2011. The car was close to stock and well taken care of. The car for me like any car fanatic started as a dream the Evo was my “dream car” when I was young and It wasn’t until I was 23 that I could make it a reality. The car itself was built and tuned by CBRD all assembly work as well as tuning was done there. I'm going to upload some before/after/ progress pictures. Ill have to find my dyno sheets. She put down just over 625hp on a conservative tune (mustang dyno) here Goes:
Car: 2006 Evo IX SSL
Owner: Ryan
ColorFormally Tarmac Black) Now House of Kolor Brandwine Red
Modifications:
Exterior
Rexspeed Carbon Fiber Exhaust Heat Shield
Tyrant Carbon Fiber J Panel Set
Rear Chrome Trunk Badging
Rexspeed Carbon Fiber Pillar Trim
Rexspeed Polarized Mirrors
Muteki SR48 Burning Blue Neon Lug Nuts
Carbon Fiber Rear Emblem
OEM Front Emblem
Rexspeed Carbon Fiber Mirror Covers
Rexspeed Carbon Fiber Vortex Generator
Carbon Fiber Valve Stem Caps
D2S Osram Xenarc HID Bulbs
PIAA Super Silicone Wiper Blades
House of Kolor Paint
Buschur Racing Front Underpanel
Rear Wiper Delete
Interior
Bride Zeta III Type-L Seats
Buddy Club Seat Rails
Tyrant Carbon Fiber Armrest Cover
Autovation Stainless Steel Door Sill Set
JDP Engineering Carbon Fiber Center Console
JDP Engineering Carbon Fiber Center Console Shell
Rexspeed Carbon Fiber E-Brake Handle
Rexspeed Carbon Fiber Gauge Cluster
Rexspeed Polarized Rearview Mirror
Bride Front & Rear Floor Mat Set
Trustz Gauge Faces
TWM Performance Big Type R Shift Knob
Raptor Performance Red LED Shift Light
Custom Rear Seat Delete
AEM 52MM (30-50PSI) Digital Boost Gauge
AEM 52MM Oil Temperature Gauge
AEM 52MM Voltage Gauge
AEM 52MM Wideband Gauge
Perrin Performance Gauge Adapters 60-52MM
Defi 60MM Red Racer EGT Gauge
Defi 60MM Red Racer Oil Pressure Gauge
Defi Control Unit
Hallman In-Cabin Boost Controller
Engine Dress-Up
Full-Race Reservoir Covers
Rexspeed Carbon Fiber Fuse Box
APR Carbon Fiber Radiator Cooling Plate
Weapon R Neo Titanium Torque Damper
Spark Tech 4G63 Billet Coil Protectors
Samco Purple Vacuum Hose
Torque Solutions Motor Mounts
Brass Battery Terminals
Odyssey PC680-P Battery
Toxicfab Coolant Reservoir
Toxicfab Mini Battery Tray
Toxixfab Titanium Cam Sensor Shield
Titanium Burnt Valve Cover Dress Up Bolts
Titanium Burnt Engine Bay Dress Up Bolts
Powdercoated Calipers, Engine Bay, Wheels, Etc.
Engine
MAP H11 Head Studs
ETS Short Route Piping
FP HTA GT3586R Turbo .82 Tial V-Band
FIC 1450 Injectors
Full Blown 70mm Throttle Body
Tial MVR 44 Wastegate
GSC S2 Cams
Buschur Racing Double Pumper
Shearer Fabrications V-Band Exhaust Manifold/ O2 Housing/ Dump Tube
SparkTech CDI Pro Coil On Plug + Polished Mounting Plate
AMS F-1 Intake Manifold
AMS Fuel Rail
Aeromotive A1000 EFI Fuel Pressure Regulator
Fuel Pressure Regulator Stainless Steel Lines + Install Kit
Turbosmart FPR Liquid Filled Gauge
Perrin Intake
Kiggly HLA
CBRD Custom Catch Can
CBRD 1” Radiator
MAP 2.3L Stage 2 Short-block (Wiseco Pistons 1400HD 85.5MM)
Carrillo Pro H-Beam Connecting Rods 3/8” WMC Rod Bolts +Clearances
Balance Shaft Elimination
OEM Oil Pump Front Case
MAP Stage 5 Cylinder Head: Combustion Chambers Match Overbore, Supertech Exhaust Valves +1mm Inconel, SS Black Nitrided, Supertech Valve Seals, Ferrea Valve Guides, GSC Beehive Springs w. Titanium Retainers & Chromoly Seats
AMS 3” Turbo Back Exhaust w. High Flow Cat
Drivetrain
Energy Suspension Rear Differential Bushings
Exedy Stage 4 Twin Disk (HD)
AMS Stainless Steel Upper & Lower Clutch Line
Buschur Racing Shifter Base Bushings
Buschur Racing Under Hood Shifter Bushings
Shep Trans Street/Strip:
New 1st, 2nd, 3rd, 4th, & 5th Gear Synchro
New 1st-2nd Shifting Sleeve
New 3-4 Shifting Sleeve
New 5-R Shifting Sleeve
New Seals, Shims, and Snap Rings
Reverse Gear Synchro
New Input Shaft Bearing
New 3-4 Fork
Evo 8 3-4 Conversion
4.11 Final Drive Upgrade
New Output Shaft
Shep Trans Stage 2 Transfer Case Rebuild
Upgraded Ring and Pinion Set
8mm to 10mm Bolt Upgrade
New Pinion Bearing Set
New Seals & O-Rings
Reshimming
Neodymium Magnet
+ Quaife Differential
Suspension
Swift Spec-R Sport Springs
Bilstein Front Struts & Rear Shocks (HD)
Brakes
OEM Brake Shims and Bolts
Powder Coating/Seals Rebuild
Goodridge Stainless Steel Brake Lines
Rotorpros Performance Rotors + Zinc Plating
EBC Red Stuff Front Brake Pads
EBC Red Stuff Rear Brake Pads
Tires
Dunlop Dirreza Sport Z1 Star Spec 235/45/R17 Tires
Stock Evo 9 Rims Powder Coated
Miscellaneous
New OEM Timing Belt Tensioner
New Gaskets: Thermostat Housing, Intake Manifold, Exhaust Manifold, Injector O-Rings Etc.
New OEM Water Pump
New OEM Accessory Belt
Vacuum Block
Custom Stainless Oil Feed Lines
Black/Purple AN Fitting/ SS Hose
Spark Plugs
Oil Filter
AWD Alignment
Tuning
Fittings Etc. Etc. Etc.
Old Nov 15, 2014 | 05:52 PM
Just a few old pictures:
A few more old pictures:
Old Nov 15, 2014 | 05:53 PM
Some more old pictures:
More old pictures:
Old Nov 15, 2014 | 05:54 PM
A few more old ones:
Parts:
Old Nov 15, 2014 | 05:55 PM
Parts:
Parts:
Old Nov 15, 2014 | 05:56 PM
More Parts:
Parts:
Old Nov 15, 2014 | 05:57 PM
Even more parts:
Final Look:
Old Nov 15, 2014 | 05:58 PM
Final Look:
Final Look:
