Seat cover "rail thing" comes off
Old May 21, 2004 | 06:55 AM
Alacris's Avatar
Anyone else have this problem:
Drivers seat, left side, towards the bottom (between the seat and the door). There's the cloth and it's attached to a metal or plastic rail. Ideally, this is sorta folded under the seat itself and held in place.
I noticed mine came off a couple days ago. Fixed it, or so I thought, and it's the same way again.
Anyone else with this problem? Easy fix that I might have overlooked? Warranty issue?
Thanks,
a
Old May 21, 2004 | 06:57 AM
kimletrim's Avatar
Registered User
Have you tried the SEARCH option?
Old May 21, 2004 | 07:29 AM
Alacris's Avatar
yes I did. I got a lot of threads talking about the pull-away problem (wrinkling of the seat back) and a bunch that seem to have nothing to do with seats.
Perhaps I searched using the wrong terms; but I always search before I post a problem. Problem is, sometimes the answers here get buried in a 500 post thread . . .
Old May 21, 2004 | 07:41 AM
Alacris's Avatar
Okay, new search with "recaro" and that narrowed it to 5 (of which only one was relavent).
https://www.evolutionm.net/forums/sh...o+seat+problem
I'll try to fix it tonight. Anyone else have it recurring after fixing?
Thwack's Avatar
all hail the mighty merge... grab a beer, lean back, prop your feet back and wade through it as best you can...
or just start a new thread like this one, get your answer quick, and let it be merged with the 500 post threads.
Old May 21, 2004 | 09:16 AM
andyevo's Avatar
I have this problem as well. Thank you Alacris for posting up the old thread, didn't know anyone else was having this problem. Anyway, I will let the dealer fix it. Funny how the only problem with my supposed low quality Mitsubishi is with the almighty Recaro!
Old May 25, 2004 | 06:20 AM
Alacris's Avatar
Update, it came off again. This time I tried really hard to make sure I fixed it right.
Turns out I was not getting it right on the frontmost clip-rail. It's almost like there's two tracks, one that it will fit on, but not tight, and an inner track with three flange/clips. Because the clips are spaced out and not continuous, I had the seat's rail in two of them but not the third (the front most flange).
I hope this makes sense. If you've had this problem, you likely know what I'm talking about. Anyway, it was harder to get it on the third flange, but I did, and it's held up for a few days now.
a
ruben7520
Apr 26, 2010 06:20 PM
funks
Jan 6, 2009 04:30 PM
avengerhed
Dec 14, 2005 07:58 AM
Mitsubeastin
May 16, 2005 05:44 AM
