Stock Sterwo Removal, Please Help!
Old Aug 18, 2004 | 07:21 AM
grett04's Avatar
I am buying a new head unit to replace the stock one. I need someone to tell me, and show pictures if possible, of how to remove the head unit from the lower din area on the EVO. My stereo isnt in the top because thats where the Mitsu guages are. Any help would be greatly appriciated.
Old Aug 18, 2004 | 07:25 AM
dpwurzer's Avatar
SEARCH THE FORUMS, ITS ALL THERE.......
i read one and it has the pics too....
check this out....
http://www.evomoto.com/tech_info.php?techID=9
4G63>OOOO's Avatar
There are 2 phillips head screws under the upper lip of the din panel. Remove screws, panel will pop out and radio pulls out after you disconnect the connector in back.
Old Aug 18, 2004 | 08:16 AM
trubidou's Avatar
Alright, I'll overlook the yelling and overall poor attitude, and try to point you in a hopefully correct direction. If this isn't whatt you want or need, please search the evo how to's/installation forum. I searched it for "stereo" and got a list of threads. This may be the one you need.
https://www.evolutionm.net/forums/sh...ad.php?t=23557
Old Aug 18, 2004 | 08:34 AM
Quickshift's Avatar
There are 2 phillips head screws on the bottom (right below the HVAC panel) after you unscrew those there is 2 push clips on the relo kit. You just pull toward the rear of the car and it will come off. It is pretty simple once you see whats holding it up.
