looking for photos of 17x9 +25, 235/45/17
I am also running roughly 1 finger gap from fender to tire.
If you get the +25, you should not have an issue at all, since it would sit inside 8mm more. However, I personally feel +17 is perfect for my application
I didn't get my fenders rolled though, I am running on aragosta coils and so far no rubbing issues except a tiny rub at the rear when going through uneven roads at higher speeds.
You're welcome. A set of good wheels are going to be considered an investment, so good on you for doing your research before throwing your money in. I'd say you could probably run wider tires if you are on +25. But on my +17, 235 is the widest I could safely run without rubbing.
To make this work properly a rear fender roll, fender pull would be needed for full clearance (the factors that enabled this to work "as is" is the 9" wheel & the 235 tire)
hytek369
Sep 25, 2007 01:25 PM
BABYEVO1
Mar 22, 2006 01:17 AM
