brake pads
Originally Posted by evoinit
do we have to bleed the brake lines
not sure need feed back
Emre
how do you do that
Each caliper has two brake bleeder nipples (one on each half of the caliper). You stick the hose on the nipple, have your friend pump up the brake pedal, then release the valve and pour off the fluid into the bottle. Periodically check the fluid reservoir and keep topping it up so you don't run out. Keep pumping and drawing off the old fluid until you start to see clear, new fluid pouring through.
Then repeat for both bleeders on all 4 calipers.
Emre
Originally Posted by Nad1370
If your going to bleed the system. Start on the caliper farthest from the brake master cylinder.
RR , LR , RF , LF.
RR , LR , RF , LF.
Many of my friends are professional road and rally racers and none of their teams follow that rule anymore. (BTW: I'm talking about professional teams, like Fiat/Abarth and Ford).
Emre
