Loose back end around corners...
Old Dec 29, 2004 | 11:50 AM
ErikT's Avatar
Question Loose back end around corners...
Hello all. This is my first post. I bought my 04 Ralliart 3 weeks ago... and I love it. I had been driving a 95 Eclipse (which I still have - can mod it up with no fear of warranty) and this is a much better car all around.
HOWEVER, a few times while taking relatively tight corners at relatively high speeds I have started to lose the back end. This issue is what I think people are referring to when they talk about "understeer", although I thought understeer had to do with losing traction on the front tires. Anyway, this is not a major problem, but I would like to fix it if it is reasonably inexpensive to do so.
Everything is stock up to this point, including those tires everyone complains about. I would upgrade the tires, but I'm married (married men will appreciate the problem of trying to replace brand new tires because they don't "perform well enough"). I CAN, however, ADD things to the car without much of a problem.
So, what is the problem, and how can I fix it for a reasonable price without invalidating my wonderful warranty?
Thanks!
Old Dec 29, 2004 | 12:06 PM
NOVA EVO's Avatar
Thanks!
Actually, what you are experiencing is oversteer, not understeer...
Old Dec 29, 2004 | 12:10 PM
ErikT's Avatar
That's what I thought, NOVA. But everyone complains about understeer on the Ralliart so I figured I must have had my terms mixed up.
BTW, sorry about putting this in the EVO forum.
So what are some solutions for correcting oversteer?
Old Dec 29, 2004 | 12:14 PM
NOVA EVO's Avatar
If you go into the corner too fast and have to jab the brakes, you'll unload the rear end of the car and oversteer...try changing how you enter the corner...you should be able to find a line that you feel comfortable with without losing the back end...good luck...
Old Dec 29, 2004 | 12:19 PM
mifesto's Avatar
first of all you are experiencing not just oversteer but lift off oversteer.. as you go hard into a turn i bet u lift off gas suddenly instead of gradually to brake and sudden weight transfer does that...... first of all assuming your winter is cold like mine, you shouldnt be driving so fast ... if you live in a nice climate, then rear swap bars will help keep both rear tires planted and reduce sudden lift off oversteer... more of a neutral feel
Old Dec 29, 2004 | 12:20 PM
ErikT's Avatar
Thanks for the advice. Actually, on at least two occassions I lost the back end without hitting the brakes at all. Maybe I was just driving too fast. Is there such a thing as driving too fast?
Old Dec 29, 2004 | 12:26 PM
ErikT's Avatar
mifesto, I live in Phoenix, so climate is not an issue unless way too much heat is an issue. Most of the the time the driving weather is great for the suspension, but hard on the engine.
One occassion I can think of off the top of my head: I was going into a sharp turn while accellerating to get a feel for what the car could do, and the back end started washing out. In fact, this was a freeway onramp, so I was probably hitting the gas fairly hard.
The thing is, I don't remember my Eclipse having this problem on the same onramp. It's raining today so maybe tomorrow I'll drive them both at that same point and see what happens.
Methodical4u
73
Jan 1, 2011 08:19 PM
Dallas J
20
Jun 21, 2010 08:23 PM
PDXEvo
Feb 17, 2008 06:42 PM
leif
46
Nov 10, 2003 07:04 AM
Claudius
Mar 30, 2002 03:17 PM
