rear absorber/spring mount
Old Mar 29, 2005 | 12:37 PM
vroomevo's Avatar
My rear looks too low.
i've heard that if i change rear absorber/spring mount to thicker ones (an inch thicker) can solve the problem.
anyone know where to get them?
any solution to raise about .5inch on the rear?
thanks for the info!
Old Mar 29, 2005 | 02:07 PM
marksae's Avatar
Why is it too low? Did you change the springs? What else did you change?
Old Mar 29, 2005 | 09:00 PM
vroomevo's Avatar
yeap. i changed spring and front drop is just fine but rear drop is too low.
looks like ' riced out honda'!
anyone has any idea??
Old Mar 29, 2005 | 09:06 PM
MYEVOVIII's Avatar
Buy different springs that have a better drop your looking for or go back to stock.
Old Mar 29, 2005 | 11:31 PM
sophis's Avatar
Whiteline coil silencers. I used them and it raised my back roughly .4" Do a search on them as I had previously posted my results.
Old Mar 30, 2005 | 12:25 AM
marksae's Avatar
Are you sure you got the right springs? The rears shouldn't be dropped that much more than the fronts. Which springs did you get? I remember reading a thread about someone's RSR springs that dropped the rear way too much a while ago. He had the wrong springs in the back, and RSR replaced them for him.
