View Poll Results: Will i rub?
You will rub
57.14%
No you will clear
42.86%
Voters: 7. You may not vote on this poll
I need advice please
I would like to know if I will rub with a 18"x9.5" wheel and 255/35 tires? The wheels are 5Zigen FN01R-C's 35mm offset. The tires are Dunlop Direzza 101's. I am lowered on Tanabe springs. Any input helps and please vote
Originally Posted by Evoisdream
im almost certin u will rub some what expessially lowerd and i beleave u will need some Decent spacers someone will know and come along
i hope this poll clears things up.
i just wanted to let the people that voted yes know that you were incorrect. Wheels are now on and there is no rubbing.
keep in mind this is a very aggressive fitment that will require lots of camber and probably some fender rolling in the rear
Why go so wide and just do a 255 tire? You could do the 8.5 +30, which is a far better fit for the evo, with the 255's and have a better overall setup IMHO
you will be cutting it real close in the rear, but you WILL need wider fenders in the front. get the Varis fenders. i'd see if those wheels come in 18 x 9. even still you will want to get the wider fenders & make sure to get an alignment as well (4 wheel laser). i also would never carry more than 1 passenger after you get your wheels either since the evos max interior capacity is only 820lbs. ABSOLUTELY DO NOT USE SPACERS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
