Tires PSI?
Tires PSI?
What for tire PSI do you go with on the stock wheels and tires? The manual states 32 psi front / 29 psi rear. Seems like the sides wear down fairly quick, sure this will happen anyway more than likely. I would think going with a little more air that what the manual says would help. Any feedback would be great. - Thanks
Yup, use the OEM pressures as a starting point, not dropping below that. From there you can tune the pressures till you get the desired feel. Don't exceed the MAX psi of your tire.
