need you input on Gramlight 57S
Old May 12, 2005 | 09:14 AM
superman105's Avatar
I have decide on a set of Gramlight 57s
17x9.5 I want to use Advan A032 275/40/17 tires
Which offset should I get for the FRONT and REAR
I did some search on it and seems there are two options ava.
+22 or +38
Do you suggest
+22 Front
+38 w/ 3mm spacer for the REAR
or +38 All the way arround with Spacers
does +22 looks different than the +38 ?
Do I need a lot of Fender rolling?
all your feedbacks are needs
tks !
Old May 12, 2005 | 10:43 AM
evo81's Avatar
gramlights 57s 17x9.5 with +22 offset all around.265/40/17 tire on them.stock suspension,no rolling.i'm waiting on my coil overs(which should be here soon),and i'll probably have to roll the back.it works
Old May 12, 2005 | 10:46 AM
XxBLACKMAMBAxX's Avatar
Pics Please
Old May 12, 2005 | 10:48 AM
PPI's Avatar
PPI
I thought people need 30 or more to run big tyres and clear the fenders....I would think 22 would be problematic.
Old May 12, 2005 | 11:00 AM
evo81's Avatar
nope i use to think that also.heres a pic
Old May 12, 2005 | 11:05 AM
evo81 that's very nice !
do you have closeup pic of the rear
I'm afarid it will stuck out
Old May 12, 2005 | 11:09 AM
PPI's Avatar
PPI
/\ looks good. r u lowered though?
Old May 12, 2005 | 11:12 AM
alex_alex's Avatar
take a picture from the side, your tire and wheel are sticking out of the wheel well.
30 offset is the lowest offset you really should be running on the stock fenders if you plan on actually driving the car.
My car is using the RRE JIC's, and the fenders are both rolled and pulled out a bit, and on a 17 x 8.5 Volk wheel on 255/40/17's, +30 offset, the tire and wheel BARELY clear.
The only way you are getting away with it now is b/c youre car is still at stock hieght.
Old May 12, 2005 | 11:19 AM
I have only question about the rear
for the front I have seen many uses 9.5 with +28 and one of the member
said Jun accutally recommends +22 for the front and +35 from the rear
Old May 12, 2005 | 11:39 AM
alex_alex's Avatar
well i can't attest to how well that setup performs, but physically, its much easier to fit bigger wheels into the front fenders than the rear, esp since its better to set up the suspension with negative camber up front
Old May 12, 2005 | 01:19 PM
evo81's Avatar
yep.here ya go
Attached Thumbnails need you input on Gramlight 57S-evopics2-024.jpg   need you input on Gramlight 57S-evopics2-025.jpg
Old May 12, 2005 | 01:20 PM
evo81's Avatar
nope.waiting for my coil-overs,and than i'll lower/roll the rear fenders,and put so more - camber on the front/rear so they can tuck under
Old May 12, 2005 | 01:24 PM
evo81's Avatar
i could of went with +35 in the rear also,but the face design won't match.this is the #2 face gramlight offers.look at the other 57S,and look at mine again.my spokes sink in,and the other face(#1) is flat looking.i like how these look over the other one's
Old May 12, 2005 | 01:26 PM
alex_alex's Avatar
but dude, you wont be able to go to the crack with these. you'll mess up both the fenders and the tire
Old May 12, 2005 | 01:30 PM
evo81's Avatar
sweet
