toe in on front tires ok?
Originally Posted by PA-silver03evo
It all depends on how far it is in. If its very much, it will wear your tires fast.
Toe in the front of a car will help to balance a car. Toe out in the front will help with a car that pushes, and toe in will help with a car that oversteers. Given that the EVO tends to push most run the car with a slight amount of toe out.
Other effects of toe:
Toe in will make the car more stable in a straight line, and will be easier to drive as the car will not hunt. Toe out is jsut eh opposite as you can imagine.
Tire wear will oviously be effected with a lot of toe in or toe out.
