Front camber bolts...?
What do you use to get a greater range on the front end? A camber bolt with the cam on it (14mm)? Mitsubishi specs either 1deg or 2deg negative camber on the front can this be accomplished with a differant bolt from Mitsubishi or is this just supposed to be the range with te stock hardware?
To get a greater range and more adjustability, you'll need something beyond OEM. WORKS offers adjustable camber plates for just this scenario.
What do you want to see? There are pics here: https://www.evolutionm.net/forums/sh...d.php?t=161812
This is before my suspension though. Weather has sucked here and my car is very dirty but if there is something specific I will try and get you a pic.
