Will this 19" setup work (for show only)
Old Sep 22, 2005 | 12:32 AM
noRtheRnEvO's Avatar
AXIS HIRO 19" Bronze Wheels Staggered Set
Complete set with tires
• Front wheels: 19" x 8.5"
• Rear wheels: 19" x 9.5"
• Bolt pattern: 5 x 114.3
• Offset for all wheels: 20mm
• Toyo Proxes T1-S Front: 235/35/19
• Toyo Proxes T1-S Rear: 265/30/19
Wheels/tires were taken off a Nissan 350Z at approximately 200 miles due to hydrolock and parting out of car.
Wheels are in excellent/good condition. No curb rash.
Tires have 99.9% tread left.
These wheels will clear Brembo Brakes.
The bronze color is hard to find. Axis Wheels is currently out of stock.
Do you guys think it is worth it?
And will it fit with a drop?
Thanks, these are going to be for show and the occasional cruise
Peope with useless information (haters) dont talk.
Old Mar 5, 2006 | 12:11 AM
Twitch's Avatar
I put on a staggered set and they work great. I rub a bit in the back but not very often at all. See my setup in my sig below... I haven't seen anyone else do this yet. I'll have some pics soon..
Old Mar 5, 2006 | 09:07 AM
EnJaNir's Avatar
Correct me if I am wrong, but damage to the AWD system could occur if the rolling diameters are not the same.
Old Mar 5, 2006 | 11:42 AM
avaien's Avatar
your right but that would be if he was running say 18s in the front and 19s in the back. width wouldnt matter, it would only affect handling. positive or negative.
Old Mar 5, 2006 | 12:10 PM
EnJaNir's Avatar
Well I say that because the rolling diameter of the tire sizes he posted although close are not the same
Old Mar 5, 2006 | 02:12 PM
JohnBradley's Avatar
Incorrect. T1S in those sizes have indentical rolling diameter, 25.4" when measured on those exact rim sizes.
This is somewhat common practice on 3000GT's where fronts have far less room than the rear wheel wells.
Old Mar 5, 2006 | 04:28 PM
EnJaNir's Avatar
Ahh I just used a tire size calculator online which came up with a marginal difference between the two sizes.
