Torque on wheel nuts
Old Sep 28, 2005 | 05:45 PM
bigfishs's Avatar
Okay, b4 I get flamed, I tried a few searches on what torque to put on my wheel nuts when I do my first rotation of the advans, but to no avail. Using wheel or torque in the search leads to lots of stuff.
Any body got the ftlb number? Also, should I use antiseize compound?
I didnt see it in the manual, but if it is please direct me.
Old Sep 28, 2005 | 06:03 PM
Airpoppoff's Avatar
No antiseize
I tourqe mine to 90ftlbs
Old Sep 28, 2005 | 06:04 PM
TPetsch's Avatar
87 ft-lb
Old Sep 28, 2005 | 06:05 PM
Kwman's Avatar
72 - 87 lbs
Old Sep 29, 2005 | 05:19 AM
bigfishs's Avatar
Cheers!
Old Sep 29, 2005 | 09:37 AM
Alacris's Avatar
Yeah, 80 ft-lbs is what I usually do.
However, check it again after your first drive around the block. In some rare cases, the wheel is not completely seated and while the lugs seems to tighten, they work loose after some driving. It's only happened to me once (on my old car), but I caught it right away and retightened.
hth,
AC
Old Sep 29, 2005 | 09:43 AM
TxEvo8's Avatar
+1 on 90 lbs..
Originally Posted by Airpoppoff
No antiseize
Old Sep 29, 2005 | 10:06 AM
kekek's Avatar
I think the manual spec's about 73 ft-lbs. I have a habit using 80ft-lbs. Thats what the spec always was for my Honda's (same lug size).
Old Sep 30, 2005 | 02:36 PM
hphan's Avatar
I have never owned a torque wrench so this might be a good time to ask: what is the harm in over-torque? I mean with under-torque the wheel nuts might fall off, but if you just tighten it enough isn't that good enough? I have always done it by hand for years and years and I have never lost a wheel nut or have had any trouble. Can someone enlighten me?
Old Sep 30, 2005 | 04:50 PM
nils_work's Avatar
over torque can be very bad.... replacing stripped wheel studs from your hub is not fun.
Old Sep 30, 2005 | 04:59 PM
zlancer's Avatar
over torqueing can snap wheel studs and warp rotors.
Old Sep 30, 2005 | 05:02 PM
badbrain's Avatar
i believe the manual says 65-80 ft/lbs. i try to do 80 ft/lbs.
Old Sep 30, 2005 | 08:50 PM
Evo442's Avatar
80 ft-lbs
Old Oct 23, 2005 | 08:55 AM
Derek888's Avatar
anyone have any idea how much torque those air guns have that the shop uses?
Old Oct 23, 2005 | 09:13 AM
VTECH8TR's Avatar
It depends on the air gun. I have 2 Ingersoll Rand impacts. One of them is strong as hell. I never use a impact on my rims, too much torque to cause alot of problems down the road.
