Installed Pics of GT Spec "Trunk Cage"
Old Oct 18, 2005 | 05:33 PM
liveiiroll's Avatar
looks great..i would assume it would help a lot in the twisties!
Old Oct 18, 2005 | 06:29 PM
Evo442's Avatar
Works carries these too if someone needs it now
Old Oct 18, 2005 | 06:57 PM
trinydex's Avatar
Originally Posted by mdosu
oh ok, thanks, when I saw this photo at first, I lost all sense of direction b/c it was zoomed in...I got the bearings now...
In theory this setup should be "better" than the Mine's crossbar right?
why's that?
Old Oct 18, 2005 | 07:02 PM
en1gma19's Avatar
l thought the Mine's crosscar was for under the car. The same place the Cusco Ver.1 and Ver.2 bars go.
JoeWalker4G63's Avatar
If the Mine's unit ties in 4 points of the trunk then it should in theory do the same thing. It is just personal preference. I just like the beefiness of the GT Spec unit and the bling. I can't seem to shake the feeling of needing some bling.
Old Oct 18, 2005 | 10:20 PM
atomicapples's Avatar
and clunking?
Old Oct 18, 2005 | 10:26 PM
trinydex's Avatar
the mines bar is one piece... and doesn't bolt on to bars... it goes onto the towers... so it's a bit different.
Old Oct 19, 2005 | 04:57 AM
Originally Posted by atomicapples
and clunking?
I get no noise from this set-up at all. Once tightened down this bad boy becomes part of the car.
Old Oct 19, 2005 | 07:45 AM
kekek's Avatar
I don't understand bracing the end of the trunk to the strut tower. I don't see where the benefit is, there are no suspension mounting points that far back in the chassis. Most of them mount to the rear subframe, forward on the chassis and the lower portion of the strut tower itself.
personally I wouldn't put money into it...Mitsu has already added a boatload of extra spot welds anyway
Old Oct 19, 2005 | 08:41 AM
Mike@Forge's Avatar
By tying the 4 mounting points together, you are essentially creating a flat plane between those for points.
This eliminates any flexing of the body between those points when there is load on the suspension and/or the body.
Old Oct 19, 2005 | 11:54 AM
trinydex's Avatar
well... one piece ensures no clunking and no need to righten anything but where it mounts to.
Old Oct 19, 2005 | 12:32 PM
djh's Avatar
djh
Without any diagonal bracing all resistance to the two rhomboid distortions comes from the strength of the corner joints. Similarly for out-of-plane distortions. But then I still haven't seen any evidence of significant chassis flex in the trunk to begin with.
Dave
Old Oct 19, 2005 | 12:39 PM
Dave
I'm sure there is some flex or Mitsu would not offer a brace for the RS. There is definately a difference felt in the car. Mostly in the form of the car feeling more "tossable". Maybe that is just in my head, but it seems that way to me and that is what counts
The part did install easy and I'm satisfied with it.
Old Oct 19, 2005 | 12:45 PM
h22gordo's Avatar
I have the same trunk cage installed in my car. Great piece! Perfect fit.
No clunking, and gives the car a more "solid" feel as JoeWalker put it.
Old Oct 19, 2005 | 12:57 PM
djh's Avatar
djh
Maybe, but it could also be marketing BS. I want to see real measurements of chassis flex and real differences in track times before I believe that this is for real.
I have a rear tower brace and don't think it makes a bit of difference. Next year when I have some good data acquisition I'll try some laps with and without. Call me ****-retentive (I'm German) but I might go so far as to double-blind it and have someone randomly take it out and put it back in between sessions!
Dave
