Unscheduled rotor replacement....
I had a perfect plan. See, once I'm through with this set of pads (Mu, Max900) my rotors should be pretty much dead. I had originally planned to, at that stage, get a brake kit (Stasis most likely).
So anyway, I had a wheel off yesterday and thought it would be interesting to find out how thick my rotors are.
With vernier calipers and standard *****, they're only 28.xxmm thick!! I think the minimum is 29.8mm or something. I'm going to measure it with a micrometer today, just in case.
The obvious thing to do would be to get new rotors, but I just changed my pads about 1.5k miles ago.
So, my questions are:
- Anyone has any experience with SCR-Pro rotors for your front? How do they compare against Girodiscs? I can get the mu's cheaper than the Girodiscs and they're both 2-piece.
- Will it be okay to run old pads (about 1500miles) on new rotors? I keep hearing pepople say that it's not a good thing to do, but these aren't like really old pads, just used a little. Will that be okay?
- How thin can I really go? I mean, I can just keep the rotors and the pads till they are both dead and then get the brake kit as I originally planned. Anyone with experience on this?
p.s. I was rather foolish of me not to have measured the rotors when i changed the pads. But my car's only done just over 10k miles.... anyway, looks like these project mu's are extremely abrasive. But jolly good though.
Never run old pads and new rotors! The old pads have a set pattern and will try to carve that pattern into the new rotors!!!!
How thin should be marked on the rotors. It is a good idea to check the rotors at least once a year. More often if you are racing.
If the pads have worn down the rotors that much in just 1500 miles - WOW - you could keep what you have but just check it every 1000 or so........ (I wouldn't but you could and you'd probably be fine)
Well, you see, the stock pads wore out at only 3x00miles. So I changed to a set of Titan Kai's. That set last me an incredible 5x00 miles. That's if i remember correctly. After that set, I changed to my current set. Anyway, the wear is from more than one set. And I seem to remember the stock pads lasting no time at all....
From what you said about the pad, dang... I think I will have to keep these on for a while longer...
No, mate. I live in probably the only country in the world where people actaully BELIEVE that drving over 50mph is fast. Most go around at about 30. Trust me, they really do.
I can be empty for miles and there will be cars lined up all across the road all doing the same speed. Amazing.
am I reading this right? You get between 3000 and 5000 miles per set of pads???? Something's not right there. Either the pad should wear or the rotor should wear, but to have a rotor below minimum tolerance in just over 10,000 miles and be on your 3rd set of pads??? jeeeez, how do you keep the brake dust off your wheels?
Had my wheels off last night had a micromenter to hand.
It seems that the previous measurements (using standard *****/rods and vernier) were off. The acutal thickness is about 30.x
Turns out the standard rods were not the size they were meant to be, so a-hole put the wrong ones in the drawer....
Well, sorry for the false alarm. At least I won't have to change the rotors yet.
Smike
628
Oct 27, 2024 04:39 AM
barneyb
Oct 4, 2013 09:30 PM
vd
17
Apr 17, 2011 04:23 AM
ambystom01
12
Jan 14, 2006 09:52 AM
