how to hook up 4 point harness.
i have a camlock, 4 point harness from sparco that im ganna put on the evo. i read somewhere that the recarros are already set up for this. where on the seat do they bolt in?
When they said the seat is set up for 4 pt harnesses, they meant that there are pass through holes in the headrest that will allow proper use of a harness. As for attaching the harness to the car, you will have to find your own hardpoints and do some drilling.
And you cannot use the child safety seat attachment points, unfortunately.
SC~
SC~
the major problem will be to find the lap belt anchors. You will most likely have to drill 2 holes through the floor to accomodate for the anchor points. There isn't much else you can do to put the lap belts in place, unfortunately.
I think the only drilling you would have to do is the lap belt setup. The harness part of it can be attached to the child safety anchors in the back without any problems.
It is basically setup for this, just the lap belt part needs installing.
