Quick? on taking off spring from shock.
Old Dec 11, 2005 | 10:40 AM
dbdude's Avatar
Ok. I cant figure out how to compress the spring. It sounds easy but i cant get the compressor in the center of the spring. The bolt itself is longer than the spring. Is the compressor suppost to go through the outside of the spring? I've tried the outside but it dont work. HELP....
Old Dec 11, 2005 | 10:56 AM
brooks1005's Avatar
It goes on the outside.Place the compessors on opposite sides of the spring.you can only pull together two of the coils.The hooks will almost touch to get the necessary compression to allow removal of the top cap without it shooting across the garage.
Old Dec 11, 2005 | 10:58 AM
brooks1005's Avatar
Compress the two center coils.
Old Dec 11, 2005 | 11:04 AM
dbdude's Avatar
Im assuming you are talking about two seperate compressors. The one they gave me is only one peice that i think is suppost to go through the center of the spring. Im beginning to think they gave me the wrong compressor. On the tein spring i can easily compress it using the center method. The part # is 27035 from autozone.
Old Dec 11, 2005 | 11:05 AM
si_eater's Avatar
^^^^+1 thats all you need it might still have a little pressure so point the nut toward a wall when you start to take it out
Old Dec 11, 2005 | 11:26 AM
brooks1005's Avatar
There is another compessor that is scissor-like which has only one threaded bolt.This type will compress the same.
Old Dec 11, 2005 | 11:30 AM
brooks1005's Avatar
Here is another...http://www.harborfreight.com/cpi/cta...emnumber=43753
Old Dec 11, 2005 | 11:34 AM
brooks1005's Avatar
Just looked looked at the autozone web site and found the tool your using.I see the dilemma with that tool.Mine work on the outside of the spring.I would ask them for this set http://www.autozone.com/in_our_store...pring_tool.htm
Old Dec 11, 2005 | 11:41 AM
dbdude's Avatar
Well i just got back from autozone. They had given me the wrong compressor!!! I got the ones that go through the outside now. Man, I could have been done with at least 2 by now. Thanks for the input fellas. I'll let yall know how its goin later on.
Derek888
15
Apr 30, 2005 10:24 PM
herbal77
Apr 6, 2005 05:52 AM
rseow
Jul 3, 2004 11:05 AM
drummerjun
Apr 11, 2003 08:32 PM
03LancerOZRally
12
Apr 2, 2003 06:04 PM
