Cutting Springs....
Old Dec 29, 2005 | 01:26 PM
Juiced's Avatar
Cutting Springs....
No i'm not going to cut my springs to were the car, i have a set of Tanabe springs and i don't want to mess with the spring compressors to get the stock ones off.
I can just cut off the stock springs with a torch right?
Old Dec 29, 2005 | 01:27 PM
Hotshot940's Avatar
um, what? Could you retype in english?
Old Dec 29, 2005 | 01:31 PM
evo_rc's Avatar
go to autozone, rent some spring compressors and make your work easier. I understand what your saying, it just sounds like it would require extra work....
Old Dec 29, 2005 | 01:32 PM
res04's Avatar
torching springs while mounted on the shock sounds like your training for the Darwin Awards. Dont do it, do it right and rent the tool.
Old Dec 29, 2005 | 01:34 PM
djskyy's Avatar
it can be done without a spring compressor if you have a impact gun....just make sure you have another buddy to step on the strut so it doesn't fly anywhere.....and make sure you look away while you're unbolting it & make sure nothings in front...it's dangerous, but it can be done...
Old Dec 29, 2005 | 01:36 PM
Juiced's Avatar
I have a set of spring compressors, it's a hassel to compress the springs to the point where there is no tension left on the hat.
If i was to torch on of the coils in half it would eliminate the tension automatically.
Old Dec 29, 2005 | 01:39 PM
fsugatorbait's Avatar
Old Dec 29, 2005 | 01:41 PM
zze86's Avatar
be careful, if you plan on doing so! It may snap under the load (remember the spring is being compressed already) and put a nice hole in you face, not worth the hazzards when you can just "rent" a set of spring compressors from autozone and do the job much safer and quicker.
Old Dec 29, 2005 | 01:42 PM
lol...he already has the compressors.
Old Dec 29, 2005 | 01:43 PM
zze86's Avatar
good, then he has no excuse not to use them.
Old Dec 29, 2005 | 02:21 PM
brooks1005's Avatar
Still going to need the compressors to get the new springs on.
Old Dec 29, 2005 | 02:24 PM
evo_rc's Avatar
exactly!
Old Dec 29, 2005 | 02:33 PM
jbfoco's Avatar
manual spring compressors are $20 on ebay mine have worked great for a long time
Old Dec 29, 2005 | 02:34 PM
992gnt's Avatar
Let us know how far the hot slag flies when the spring pops.
Old Dec 29, 2005 | 02:52 PM
purecoda's Avatar
i was going to be more technical about it, but this pretty much sums it up!
