need help with my tein flex please!!!
Old Jan 2, 2006 | 11:17 AM
onesicklambo's Avatar
hey guys just installed my flex, was a pretty easy installation. But i need help with something. Both the front and rear have about a finger's gap between the fender and the tire...the front rims's camber is perfect, but the rear camber looks like a honda on chopped springs. the top of the rear rim is way further in then the bottom. I dont know how to fix it! I know these are 2 way adjustable(adjust the part that holds the spring and ALSO adjust the whole threded body itself) i have tried different cominations of moving the whole body higher, spring lower. then trying it with the body lower and raising the spring part. Am i a dumba** or does anyone know what im doing wrong..if they can even understand this. lol Also, when the car is up on jacks, rims off. IS IT BAD if the spring is "floating" i.e i can move it around, its not tight beween the pillowball and the adjuster rings? THanks alot!
Old Jan 2, 2006 | 11:55 AM
stiklr's Avatar
Get An Alignment
Old Jan 2, 2006 | 12:01 PM
bbbwrx's Avatar
Yes what you are explaining is negative camber It is not adjustable on the rear coilovers
The camber adjustment is on the car itself.
Ben
Old Jan 2, 2006 | 04:41 PM
SilverShadow03's Avatar
Thumbs up
Installed my Tein SS coilovers the a few weeks ago and the alignment was all screwed up....get that done and you should be fine.
eastcoastoutlaw
Oct 3, 2013 11:10 AM
tsi90awd
76
Dec 29, 2011 11:15 PM
m0nkie
Nov 6, 2011 05:10 PM
DrivenConcepts
Evo 'For Sale' Suspension / Brakes / Handling
47
Aug 7, 2006 08:30 PM
EarsLikenElf
31
Jul 19, 2005 07:01 AM
