I Need Supspension Help!!!!!
FYI: Top ESP/BSP/SM Autocross Evo's run 800-1100 lb springs (14.2k-19.6k), of course with R-tires. Speed World Challenge Touring cars run 1000-1200 lb springs (17.8k-21.3k) which are a bit lighter in terms of car weight, than the Evo. But then again, their not running Buddy Clubs.
Dave
Dave
Originally Posted by x838nwy
imho, there is nothing magic about having the same rates front and rear. And really i don't see the need; the loads are different and the damping values are different (in the stock setup). What _is_ more important is that your springs match your damping and to a certain extent ride height.
Taking Ralliart as an example, they do 3 suspension kits for the evo8.
1)Height adjustable made by Bilstein: 12f/9r - helper springs up front
2)Height adjustable sports kti: 6f/6r
3)Non adjustable, for domestic Gr.N: 5f/5.5r
(1) has a recommended ride height of about 30mm lower than (2) at the front and 35mm lower at the rear. The way it is shown is not clear how this relates to stock numbers.
(3) is 5mm taller at the front and 10mm taller at the rear compared to stock.
Some from Tein
4)Type HT for Gymkhana: 16f/12r - standard, can be purchased with other springs.
5)Super Street: 6f/6r
6)Type RA: 12f/9r
(4) is just crazy. I don't know how much it lowers the car, but what I've seen of it is LOW. And really, 16 up front is just asking for a hernia. (6) to me is strikingly similar to (2) including in appearance and fits with stock upper mounts, but lower the car by 35mm and 10mm respectively. Type RA is their 'racing' type but it's unclear as to what kind of racing this is, but it is part of their premium line. {their Gravel spec, Type HG comes with 6f/6r also, but fits 15" wheels.}
Carrozeria Japan (pretty much Ohlins Japan)
7)Flag-L: 12f/10r
8)'Standard' kit: 10f/8r
(7) is probably the best coilovers in the world, save proflex. Lowers 45mm front and 35 read. (8) is their cheaper kit, lowers 40 and 30mm.
GAB
9) Prosso Zero for VIII and MR: 10f/10r
10) Prosso Zero for VII: 12f/12r
(9) lowers by 35mm at the front and 30 at the rear. (10) lowers the rear by 35 but the front by a stunning 50mm.
I believe that most suspension kits out there have relatively stiff springs up front because of the agressive lowering, specially the Japanese kits. Having soft springs will just bottom out.
Tein S-Techs lower something like 35mm and are relatively soft. However I think they recommend you cut the bump stop rubber by around 30mm or so on both ends.
Also, the stock softer front end is probably there for comfort and to reduce the tendency for the front to push, while the rear can be stiffer since there's nobody sitting there (who expects any kind of comfort anyway) and a more slidy rear will help the understeer. This would agree with your observations about ff and awd cars since they both tend to understeer. However, I could be totally wrong.
It would be very interesting to try out a bunch of spring rates, but that means getting your hands on a bunch of springs and a lot of time on a track. What you'll most likely find is that what you prefer might not be what somebody else prefers. If you're not sure, I'd either seek to drive one with a similar setup to what you're thinking of or not go to extremes with you rates.
Some from Tein
6)Type RA: 12f/9r
7)Flag-L: 12f/10r
GAB
thanks man, and you are right. FF and AWD do have more of a tendency to understeer. for example, my accord stock understeered like a *****. i set it up stiffer in the rear through shocks/sways, and i believe the springs are stiffer in the rear but i'm not 100% sure... the accord now turns really neutral and i can get it to slide all 4 wheels, and oversteer on command. if i can get my EVO to handle like the accord, i'll be happy. i think i'm gonna go ahead and order the 9k/9k Buddy Club setup.
Dave
Dave
speed world challenge cars actually run stiffer than that. i know the RTR RSX's run up to 2200lb springs. that's stiffer than what i'd like to ride on everyday though lol.
9/9, or 10/10?
Originally Posted by wingless
Thats just so wrong.
Working hard to make and EVO handle like an Accord is just criminal.... Hey the Accord is a good car if you can't step up to a Buick. If you hate your EVO so much, please just sell it and get another Accord
Originally Posted by silverEVO8
+1....
lol you say that because you don't know my accord. you do realize that a STOCK EVO is not the end all, beat all, pinnacle of greatness in handling and cornering right? yeah, stock to stock, the car is a monster and can handle just about anything out there. but with suspension upgrades and tuning, other cars will out handle stock EVO's. for anyone to say otherwise is just blind arrogance. i wouldn't expect a stock car to handle better than one with 4k of suspension work done to it.
what i meant by my first statement is, predictible, controllable grip, and flatter cornering. right now the thing feels top heavy, and not as planted in turns. it also suffers from bump steer, and hopping on mid corner bumps. problems i've never had in the accord. once i drop it and stiffen it up it'll be at a higher level with the EVO than the accord obviously, but as of right now the accord corners as good or better in some situations than the EVO does. it just lacks power. if the TSX (the real accord, and dominator in speed world challenge) had more power, i'd be driving one right now. if honda ever decides to get serious and make an SH-AWD turbo'ed TSX, or at least the SH-AWD (i can turbo it myself) i'll be trading that MR with quickness. i'd have more power, a more advanced AWD system, and an better quality.
Anyway, i'm getting ready to order the coilovers. i just got back from the bodyshop to check on my EVO. they cf hood and trunk are on, they just need to do the paint work now. i should have it back by friday. can't freakin wait.
well, i must have been onto something...the standard buddy club racing spec coilovers used to come in 9kf/8kr, so i wanted to order 9/9...after i ordered them, i got a call back...turns out they've abandoned the 9/8 setup, and the standard setup is now 10/10. sweet *** lol 3 week wait on them though :-\ thanks to big J Sizzle (Jeffrey) at 500whp.com. he hooked me up with a damn good price on these, as well as the seibon CF hood and trunk i got for the MR.
.... I don't want to hate or slam your Accord but I've owned a number of those of various vintages and I can tell you without a doubt that they are pretty lousy handling cars as they roll out of the showroom floor. Honda has many nice , good handling cars, but the stock Accord is not one of them... Props to you for having made a decent handling one, but I bet the stock EVO in the right hands will definitely do the job
first off, a chevy cavalier should never be mentioned anywhere near a honda accord and especially not an EVO. second, what car dominates the speed world challenge? TSX. Praised by racers all over as the best handling front driver they've ever driven. Take a TSX and 98-02 Honda Accord, and compare them. same double wishbones at all 4 corners, very similar chassis constrution, good balance, and rigidity. if the TSX can do it, so can the accord. from the factory the accord is a good handling car. it really just needs decent tires. setup right, it's a great handling car. "decent handling" doesn't describe my accord at all. i've waxed S2K's with stock suspensions, beaten WRX's, G35's, 350Z's, IS300's, Civics, Integra's, Preludes, Miata's, and in autoX i normally finish anywhere from .5-2 seconds behind EVO's. that's because of the gross power difference, not the handling. i took both my accord and EVO to an autocross. my first time out i took first place in the EVO against the regional champion. i then took the accord out for a fun run, and where the EVO slid and squirmed, the accord planted and turned. the time was slower because it was a huge track with big str8's. the accord was faster through just about every turn, and felt alot better around the skidpad in the middle. when you buy an accord and tune it, then tell me what they are capable of. until then, stick to chevy cavaliers since you seem to like them so much. with more power, my accord wouldn't have anything to worry about running with the EVO's. If i hadn't decided to get the IX MR, i was planning to swap in a K24 from the TSX along with the 6speed and a comptech SC. that would have taken care of everything. I may still do it just to show people like you, who don't know jack **** about the car exactly what the car can do.
Congrats on your great driving and your great Accord. BTW, your sig says it all
but back to the topic... for those that missed it, BC racing spec's ordered. 10k f/ 10k r...the new standard setup for the BC's which makes alot more sense than the 9/8 setup. should be here in 3 weeks. thanks again to all the people with helpful posts, and Jeffrey at 500whp.com for the hookup on the coilovers (damn good price), and the hook up on the cf parts i ordered last month.
i need to modify it to "i hate people that don't know jack **** about ****, but pretend they do instead of just shutting the **** up"
