Need help
Need help
I'm sorry I'm new at this and I did search but what I found I don't understand. So my question is I am getting 18x9.5 I am not sure what the offset is, and I have stock suspension I am wondering are the going to rub the rear fenders? I have 20mm wider fenders on the front and the tire size is going to be 235/40/18. So are they going to fit right Or am i going to have to roll the rear fenders? Thanx for your help and please no flaming
BTW, why should we help you, your are a psycho
They should fit just fine:
The total diameter of the 18inch rim and 235/40/18 tire = 645.2mm
The stock wheel and tire diameter = 643.3mm (difference of 1.9mm is nothing)
The important thing is what the offset of the rims you are getting is ... if there is very little +ve offset the rims might stick out too much and you tires may rub.
