Wheel studs?
Old Apr 17, 2006 | 12:14 PM
Fisher22's Avatar
Wheel studs?
Well after putting my stock tires back on from last weekends autocross i found that two of my studs are stripped. This happened before and the shop replaced the whoel hub assembly. Is this nesissary or can you replace the individual studs? the hub is around 160 and i'm really hoping you can just replace the individual studs. Also let me know where you can get the studs from if you can. Thanks
Old Apr 17, 2006 | 12:58 PM
instigator's Avatar
I have bought replacement studs at autozone and replaced them in no time.
Old Apr 17, 2006 | 01:26 PM
kekek's Avatar
Studs are available individually. I would wonder about quality coming from Autozone or Pepboys, especially if you are a frequent tire changer. I would go with OEM for stock length or RRE or ARP for extended lengths.
Old Apr 17, 2006 | 01:35 PM
Fisher22's Avatar
ok, thanks, i'll have to call up the shop that my evo is at now and let them know
Old Apr 17, 2006 | 01:44 PM
WW3900's Avatar
I would just get replacement ones from the dealer. they sell them individually for arond 2 bux each. If you are running stock wheels with stock lugs, you won't be able to use longer ones unless you change the lugnuts...
Old Apr 17, 2006 | 08:08 PM
Fisher22's Avatar
just had my shop order them, much nicer than spending 160 on a new hub...haha
