Lower the Evo
Old Apr 20, 2006 | 07:53 AM
HUTCH1991's Avatar
Lower the Evo
Is there anything that will just lower the evo with out spending tons of $$$$$
Old Apr 20, 2006 | 07:56 AM
WHTEVO's Avatar
There are plenty of threads about this. But if you looking for something for lowering and not expensive just go with some springs. I used Tein S-Tech for a while before i switched to Cusco Zero 2R coilovers. Good luck.
Old Apr 20, 2006 | 08:00 AM
sspeed's Avatar
Be careful... Just lowering the car with springs in most cases will make the handling suffer.
Old Apr 20, 2006 | 09:49 AM
WW3900's Avatar
yeah, if you just cut the original springs.... or buy some off a geo metro
Old Apr 20, 2006 | 09:52 AM
WW3900's Avatar
Check this thread out... https://www.evolutionm.net/forums/sh...ad.php?t=66296
It has both lowering springs and coilovers rates....
if you go too stiff of a spring, your stock struts won't last very long. Just go over some of the spring rates and if lowering your car is the only important thing to you, choose one that has "soft" rates.
Old Apr 20, 2006 | 11:34 PM
ScoobySAM's Avatar
yea..u can get lowering springs. My h and r springs ride greattt and didnt cost much
Old Apr 23, 2006 | 10:02 AM
HUTCH1991's Avatar
thank guys
Old Apr 23, 2006 | 10:09 AM
EVOL EDO's Avatar
worst information ever. its the drop that makes the stock struts not last very long. and stiffer springs dont wear them out faster softer springs will because they have to do more work. but choosing spring rates that dont work with your stock suspension will cause handling to suffer. a cheap set of coilovers is better than just springs. remember this car isnt a civic. so unless you want it to just look good and dont care about the handling that made it famous go for springs. either way if you choose springs or coilovers research the brands you are looking at.
Old Apr 27, 2006 | 09:54 PM
03silverevo8's Avatar
its gonna cost you alot of money cause you got an evo
