I need the Rotors Thickness!
Old May 5, 2006 | 02:55 PM
FoIce's Avatar
Please I have to know the Thickness of the Evo´s stock Rotors :
320 mm front
300 mm rear
Thickness? 28mm?
Thanks!
Old May 5, 2006 | 10:00 PM
96_LXR's Avatar
Here ya go . . . looks like the fronts are 32mm and the rears are 22mm
SERVICE SPECIFICATIONS
M1351000300392
ITEM STANDARD VALUE LIMIT
Brake pedal height mm (in) 169.1
- 172.1 (6.7 - 6.8) -
Brake pedal free play mm (in) 3
- 8 (0.12 - 0.31) -
Brake pedal to floor board clearance mm (in) 90 (3.5) or more
Front disc brake pad thickness mm (in) 10.0 (0.39) Minimum 2.0 (0.08)
Front disc brake disc thickness mm (in) 32.0 (1.26) Minimum 29.8 (1.17)
Front disc brake disc run-out mm (in)
- 0.03 (0.0012)
Front disc brake drags force N (lb) 69 (15) or less
Rear disc brake pad thickness mm (in) 9.0 (0.35) Minimum 2.0 (0.08)
Rear disc brake disc thickness mm (in) 22.0 (0.87) Minimum 20.4 (0.80)
Rear disc brake disc run-out mm (in)
- 0.03 (0.0012)
Rear disc brake drags force N (lb) 69 (15) or less
Front wheel bearing axial play mm (in)
- 0.05 (0.002)
Rear wheel bearing axial play mm (in)
- 0.05 (0.002)
Brake booster push rod protruding amount mm (in) 8.98
- 9.23 (0.354 -
0.363)
Old May 8, 2006 | 11:15 AM
FoIce's Avatar
Thanks....! and what about the calipers?
Old May 8, 2006 | 11:25 AM
nubby's Avatar
Registered User
what do you want to know about the calipers?
ITEM SPECIFICATION
Master
cylinder
Type Tandem type
I.D. mm (in) 26.9 (1.06)
Brake
booster
Type Vacuum type, tandem
Effective dia. of power cylinder
mm (in)
205 + 230 (8.07 + 9.06)
Boosting ratio 4.5 <Brake pedal depressing force: 230 N (51.7 lb)>
Rear wheel hydraulic control method Electronic brake-force distribution (EBD)
Front brakes Type 4-opposed piston, ventilated disc
Disc effective dia × thickness
mm (in)
263 × 32 (10.4 × 1.3)
Wheel cylinder I.D. mm (in) 40.0 (1.58) × 2, 46.0 (1.81) × 2
Pad thickness mm (in) 10.0 (0.39)
Clearance adjustment Automatic
Rear brakes Type 2-opposed piston, ventilated disc
mm (in)
252 × 22 (9.9 × 0.9)
Pad thickness mm (in) 9.0 (0.35)
Brake fluid DOT3 or DOT4
